1994 stalling during acceleration
I have a 94 that, while accelerating it seemed to choke then stalled out completely. After getting off the side of the road tried to restart with no luck. What could be causing this. It was doing it occasionally but would correct itself but this time died. Will try to turn over but no luck. HELP !!!!!
I would put a fuel pressure gauge on it. Might just be as simple as a fuel filter. If it is cold now turn the key without turning over and listen for the pump. It should run for two seconds and see if any fuel comes out the schrader valve if you don't have a gauge. Could also be your sock, pump, fpr or pulsater.
