Corvette -92, module 9 fault code H64
4th Gear
Can someone help me with that fault code problem?
If I read right way it means TPS-sensor? But I tested it and it show right data.
There burns also "infl rest light" on the dashboard. Does it comes with that H64 problem? Or is there still some kind of other mistake.
I removed codes several times but that H64 code stays.
I cleaned airbag sensor from front left but it does not help.
I have tried to find help here from other topics but not succeed.
Sorry my bad english.
Mikko
Mikko
Mikko
Mikko
You can check the SIR for flash codes BUT I don't believe you can clear them manually on a '92. Did you use the "flash codes" to diagnose the SIR code OR did you just rely on earlier information that mentions cleaning frame mounted sensors?
MikkoT, any update on your issue ? I am having the same problem and just pulled the module Dave is talking about and all the connections look OK. The box has a circuit board with a bunch of resistors on it. I checked all the solder connections and wires to the box.
4th Gear
I found broken wire between tps-sensor and tps-module. I made jumper between them and fault was solved. Next I have that another problem (infl ration) to solve.
Mikko
Mikko
