slight, rough idle, 1990 L98, looking for comments...
update: well. I finally fixed the idle issue. as suspected, it turn out to be an injector problem. I took advantage of FIC's Columbus day discount on another set of bosch3's ($155 shipped) - installed, and problem solved. happy camper! my original injectors ohm'd OK - 15 ohms +/- .5, and they chattered OK, so i'm assuming the solenoid internals were good. only thing I could figure is a flow issue. i'm going to try to rig up something to flow test #3 to confirm my suspicions. anyway, smooth idle, and no low end pulsing on acceleration -
that maybe right, and not trying to be a wise ***, but why? seems to me if you stop the fuel source to any cylinder, it will effect the idle quality. I suspected a flow issue and swapping out the injectors did significantly improve my idle quality. i'm by no means a diagnostic expert, and my knowledge in these areas is mediocre at best.
Without a flow bench, the most the rigging can do is give you an approximate of what it might be depending on the limitation of your imagination.
They particularly noted that going with aftermarket injectors can cause rough idle. This is because the car fuel injection system was calibrated to those particular injectors, and different injectors can have slightly different behavior, even if both are rated 22 pounds.
The Delphi OEM injectors are about $500 for a set, and you may not want to go back, take out the aftermarket ones, and put the OEM ones in. But from what I was told, it would likely solve your idle problems. I suppose alternately you could get the car recalibrated for the aftermarket injectors, but that's probably as costly as putting in the correct ones.
Also, my 1990 has a rock steady 20 vacuum not 18. Aside from the aftermarket fuel injectors, you may have something else going on too.
And by the way, ignore the nonsense about Delphi injectors from 1990 not handling ethanol fuels - ethanol was long in use by then, and my original injectors lasted 26 years before having a problem.
As to ethanol being used in fuel, how long has it been in use? IIRC, back in the 90s it was harder to find fuel with ethanol. Today, thanks to the govt, it is everywhere except in Marinas or a few select places. Back then, the probability of getting a tankful of ethanol was slight. Today, you can't swing a dead cat without hitting a pump with ethanol as the saying goes.
re-read;
update: well, I finally fixed the idle issue. as suspected, it turn out to be an injector problem. I took advantage of FIC's Columbus day discount on another set of bosch3's ($155 shipped) - installed, and problem solved. happy camper! my original injectors ohm'd OK - 15 ohms +/- .5, and they chattered OK, so i'm assuming the solenoid internals were good. only thing I could figure is a flow issue. i'm going to try to rig up something to flow test #3 to confirm my suspicions. anyway, smooth idle, and no low end pulsing on acceleration -
"reputable shops" is one reason why I do my own wrenching!
you haven't followed my post - with the new bosch3's, PROBLEM SOLVED! no other changes were made to the engine.
re-read;
as for the reputable Corvette shop's expertise, I can not comment on the calibration thing. all I can say is this was my 4th boschIII install in L98 C4's (plus, one in an 96 LT1). aside from one slight idle issue, with one set in my (current) 90, I have not had any other problems. there are probably a hundred members here as well as the third-gen Camaro forum that have gone with boschIII's - haven't heard much negative feedback.
re-read;
