Oil filter stuck
I'm having the same problem with the k&n's was driving me crazy they all leaked. Switched to a different brand no more leaks.
My 2 vehicles didn't leak with any filter yet..
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
When I last encountered a stubborn oil filter, I used a muffler gun and cut off tool.
Just a few taps on the base and she spun right off.
Just had the same problem on a used Jeep I bought. Picked up this tool from Harbor Freight. It worked great.
http://t.harborfreight.com/automotiv....google.com%2F
http://www.ebay.com/itm/TEKTON-5866-...0AAOSw-4BXYf4D
Kind of like the one I just bought on ebay. I haven't used it yet, but last year when I changed mine on my '91 it took a while to break it loose.
pezter22 (06-17-2016)
Next I tried these and the chain thing did nothing but chew on the filter some while the jaws dented the filter and then the fingers bent on the jaws :
This type is what finally worked but the filter was so mangled when it let go finally you couldn't even tell it was a filter anymore. I have that filter somewhere and will try to find it to show the effects
Anyways THIS is what you need to remove any oil filter it seems.
HAD2HAV2 (06-17-2016)
#33
FWIW, this is what i currently use for filter removal, and for me, it seems to work just fine. I might add, that I usually only remove filters that I've installed, and I only hand tighten per manufacturers instructions. pretty sure problems arise from improper installation - over tightening and not pre-lubing the rubber gasket. everyone will have their own favorite tool and procedure, so what ever works for you,
#34
