Best way to remove batwing bushings?
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Getting ready to put a C4 batwing on my '69 as it's several pounds lighter than the C3 batwing currently on the car. In the process I want to swap in some new (poly) bushings. I'm in the process of using a hole saw to cut out the majority of the bushing, and then do some cutting and chiseling on the sleeve, but so far it's pretty slow going. Anyone have some tips on making the bushing removal process go a bit faster?
Any helpful suggestions is greatly appreciated.
Max G’s
If you damaged them already, burn them out.
Pro Mechanic
Drill through the bushing a bunch of times, parallel to the bolt. Then push the rubber out. Use a hammer and punch or an air hammer, "cave in" the outer metal shell, then push it out (if it doesn't fall out).
You know that the C4 batwing bolts to a D36 or 44 rear...your '69 should have a 12 bolt rear. Different rears, different flanges.
69427 (06-25-2016)
I'll give the multiple parallel drill holes a try.
Pro Mechanic
Cool! I dig it.
I haven't tried this way yet but saw it on FB awhile back and would use it for out of the car like you have.
Being alum I prob would be careful to not melt it and use propane or map. Then just crush the sleeve in and beat it out or cut it like some do on here with a hacksaw blade.
I'm gonna do mine in car so I'll prob do the drill & hacksaw method, using a compact hacksaw.
I just did this 2 weeks ago. on my spare dana 44. heated up with MAP gas. removed the inner steel sleeve. then softened up the rubber. Popped the remaining out. The outer steel sleeve shim. will need to be pressed out. upgrading to poly.
PS. smells great!!! Less filling!!
You need to be careful heating aluminum it's easy to turn a good part into recycling. I used 4 lb hammer and chisel once you get steel sleeve moving it not too bad Poly is a noise and vibration amplifier. I went all poly and changed gears and it's ....that's what they make radios for .....
I used a piece of threaded rod, a big deep well socket for the receiver, and a socket about the size of the OD of the bushing as the pusher a couple of nuts and washers on either end, my 1/2 inch impact (or wrench) they came right out. No heat and more importantly no sweat.
69427 (06-25-2016)
Got the bushings out. I combined the drilling and impact wrench suggestions. Went smooth, and took maybe 5-10 minutes per side. I appreciate the help.
