1994 duals vs x pipe
I've searched, but can't seem to find a definitive answer. I just completed an LE2 build. I have TPIS LT headers, true duals all the way back, cat delete, no x pipe. It seems everyone runs an x pipe. What is the reason? Should I install x pipe and why? Thanks
IIRC, the idea is to balance the flow to maximize scavenging effect for the low to mid range. Open headers are great for WOT.
Pro Mechanic
The functional reason why you'd install one is that it behaves like a "termination point" in your secondary piping -the piping after the collector. In a properly designed exhaust, the secondary piping would be a specific length, tuned to enhance torque at a specific RPM (likely the RPM that your engine makes peak tq). You can terminate that pipe a number of ways: have it open (that would be the end of your exhaust system, but wouldn't be street legal). Have it dump into a large box, install a cross over ("h-pipe") at that point, or install an X at that point.
The functional problem with H and X pipes in exhausts in most street cars is that there is a catalytic converter upstream of the H or X, and that converter acts as the termination point of the secondary pipe. So, if you've designed a system with specific length primary (header tubes) and specific length secondary tubes, then you can install your X at the termination point of your secondary tubes. Otherwise, you can install one for sound.
Is there any proven gain with the true duals besides the fact that it was the old way muscle cars were?
Pro Mechanic
Are you asking me? Gains vs. what? The stock LT1^ exhaust is effectively "true dual", so, I'm not sure what your wanting to compare...
Good question. I think the number one reason why people install an xpipe is in search of better sounding exhaust. I think the number two reason is because it's "cool"; the thing to do, in exhausts now days.
Do you think an X pipe help this sound?
The X pipe will give you a different sound. Usually a higher pitched exhaust note, not a deep rumble. It will scavenge the cylinders better at low rpm. May make your popping sound worse - can't say for sure but I thi nk the popping has to do with the low backpressure you have, I wasn't sure if You had any mufflers? If no mufflers, adding a resignator rather than a muffler may clear it up. That was my experience with a firebird i raced which sounded horrible from idle to 1500.
The H pipe changes the sound, more rumble. It only balances the pulses, that's what hanges the sound, it doesn't improve hp/tq like the X.
On a related note i always wondered if the X pipe craze started with the nascar circuit. Those guys run X pipes.
I should also mention if you decide to add one or the other where to put it. Paint your exhaust pipes downstream of the collector, start the car watch to see where the paint burns off. This is the hottest spot in the pipe and you put the H right where the paint is still present. Doesn't always match with other parts of the car that are in the way...like the tranny or cross braces, etc. the X goes as close to collectors as possible.
Could be. Kinda why they say "Win a race on Sunday, sell a car on Monday" or "Monkey see, monkey do". Might be the right thing or might be the wrong thing but if the race cars do it, I want to do it. Never mind that the motor and circumstances might not be what I am doing. Kinda like the sound you are talking about. Old muscle cars sounded like this, I got to make my car sound like it. Might be because they had no choice due to the technology hasn't caught up but I want to make it sound like the old muscle cars so others think I am powerful.
Received 3,043 Likes
St. Jude Donor '05
your popping may need to be diagnosed esp if it goes away with throtttle doubt its the exhaust
If youre hoping put one in will make it faster it wont
As posted it can tone down some of the brappiness, little smoother note
What works for a purpose built NASCAR motor doesnt always do anything or is needed on the st as they are after every last hp;thats why we dont need 260cc heads
Does your motor really need more scavenging? There is such a thing as overscavenging; really just splitting hairs is all
Id say figure out why its missing which is probably something minor go from there.
ive used true duals, H, X on various cars other than a slight pitch change never felt one bit of difference one way or the other regardless of "theory" or some mag article
Like having none just makes working on the car easier
Going to 3" over 2.5 will just make it louder inside
Does your motor really need more scavenging? There is such a thing as overscavenging; really just splitting hairs is all. Id say figure out why its missing which is probably something minor go from there.
Shelby put the H pipe with the 289/302 mustangs to help with torque Ford brought it back for the Fox body 5.0 off road exhaust. It really has to be in the right place to get the benefit . With the C4 layout; I think the crossover is to far back for a large gain. If it is put where it belongs there would be a 21/2 inch pipe hanging down behind bell housing. Chevrolet did such a good job tucking everything into the floor, and designed the engines to have plenty of torque.
There is a science to exhaust flow and there is way more to it than I know. Biggest thing true duals does is reduces back pressure compared to a factory exhaust which usually increases horsepower and torque. The factory looks at 1 big cat per car is cheaper than 2 smaller cats, everything is a compromise between cost and benefit. Cost tends to be deciding factor. Some cars layout limit what can be done with out modifying the floor pan. The Gen 3 F body snaked the mid pipe under the floor pans actually allowing for a large single exhaust pipe, and makes running 2 pipes is PITA There are those who believe the all in to one is the best. In NASCAR you can find headers feeding 1 big oval exhaust pipe or headers,H pipe, and 2 exhaust pipes.
Pro Mechanic
Tried it with having the Y pipe removed. No appreciable difference.
Perhaps so but their engines are completely different from ours and they don't have to worry about how much it costs to replace or how often. All they car about is to win the race today.
I think it depends on what you have to start with. The lt1 exhaust flows better than the l98. IMO 21/2" is the largest diameter pipe for a normal street driven car. You do want to "fit" the application, from my experience manuals do better with larger pipes than automatics. Bigger isn't always better it can make for bigger talk and a slower car. Pro Streeters or other forms of race cars with licence plates are another matter.
Does it make a difference as to what the exhaust is? I know my 3 inch is post cat.
Pro Mechanic
Every part of the LT1 flows better than every part of the L98 exhausts. From the heads to the tail pipes.
