Long Crank To Start...now even more.......
Old 07-11-2016, 11:27 PM
  #61
aklim
aklim's Avatar
Received 2,214 Likes on 1,928 Posts
Originally Posted by papatioman
I have replaced most of the fuel system & ignition system which is what I normally do with any used car, especially a classic that I purchase. This gives me a better car and I know what is new and how long it has been in there, so I haven't done anything or spent any money that I wouldn't have any way. Before I spend a lot of time checking wiring, sensors etc., I am considering having the ECM repaired or purchasing a new one. I left the car sit too long this past winter and ruined a battery because of it. I have a new one in there now. This may have caused damage to the ECM. I had a company rebuild the fuel injection control module for my Ford 350 Super Duty, best thing I could have done for the truck. I'm sure there is a company out there that rebuilds ECMs & offers different programming packages as was the case for my FICM. Will look around for a while. At least I will rule that part out as being bad.
My PO gave me a bum ECM. I got one from a parts house. On another vehicle, I got it from GM. Both rebuilds have functioned well.
Old 07-12-2016, 09:44 AM
  #62
papatioman
papatioman's Avatar
I was thinking on this problem last night and I happened to recall a similar issue I had with a 70 Nova that I had years ago. Turned out to be the ignition switch. I will hot wire the distributor direct from the battery to see if the problem is eliminated.
Old 07-17-2016, 06:43 PM
  #63
papatioman
papatioman's Avatar
UPDATE: Since we know the long crank to start is a known ECM issue with the 89 model my attention this weekend on was on the start/stall issue. Set the car up with pressure gauge on fuel rail, strobe light on plug wire and voltage meter on Bat terminal of distributor. At key on, fuel pressure is at 42psi. After key off, pressure was still at 10psi an hour later.
While running at idle, pressure is at 39psi. It took 7 attempts at starting for the engine to idle....same as before.....start die....start die. Each time it died I monitored the fuel pressure, distributor bat terminal voltage and spark plug wire strobe. No loss any where. Installed a new intake manifold CTS with no change. Cleaned the MAF sensor with alcohol .....no change. I have the throttle body removed with the TPS & IAC removed. Thoroughly cleaned the throttle body and ohm tested the TPS and IAC, both are within parameters. I ran a jumper from the battery to the distributor which rules out the ignition switch. I have noticed that even during a warm start the engines stumbles momentarily to idle then recovers. Will move on to the ECM next.
Old 07-17-2016, 06:50 PM
  #64
aklim
aklim's Avatar
Did you take the IAC housing off with new gaskets? Did you set the IAC using the IAC counts?
Old 07-17-2016, 06:59 PM
  #65
ex-x-fire
ex-x-fire's Avatar
Try unplugging the MAF sensor to see if it fires up.
Old 07-17-2016, 07:12 PM
  #66
papatioman
papatioman's Avatar
I haven't reassembled the throttle body yet. Don't have a scanner to determine counts.
Old 07-17-2016, 07:13 PM
  #67
papatioman
papatioman's Avatar
It eventually fires up and runs great after 6-7 attempts. Will try your idea......
Old 07-18-2016, 10:29 AM
  #68
papatioman
papatioman's Avatar
Any recommendations on a scanner that won't break the bank. Also, can one be bought that is both OBD1 & OBD2 compatible.
Thanks.............
Old 07-18-2016, 10:55 AM
  #69
Dt86
Dt86's Avatar
Any recommendations on a scanner that won't break the bank. Also, can one be bought that is both OBD1 & OBD2 compatible. Thanks.............
You can find the snap on mt2500's fairly cheap but they are limited on obd2 capability. It's a godsend for my 86 though.
papatioman (07-18-2016)
Old 07-18-2016, 06:51 PM
  #70
aklim
aklim's Avatar
Thanks.............
Not knowing your location in the profile (Hint: Update it so we might be able to help you better in future), I would say you should take a run to an Autozone, O'Rileys, Pep Boys or whatever you have there and borrow their scanner. If it works and it does OBD2 also, you have a winner. That or scour for a Snap ON MT2500 or a Tech 1 if you can get it cheap on Ebay.
Old 07-18-2016, 09:54 PM
  #71
papatioman
papatioman's Avatar
Thanks for the info.....will update profile. In today's world....I hate giving out too much information.
Old 07-18-2016, 10:05 PM
  #72
aklim
aklim's Avatar
If you don't feel comfortable, give a nearby town. The info you give will allow us to recommend a facility near you for certain jobs you cannot and/or will not do. Also, if I am near someone having trouble and I have tools, I might be able to make an appointment and give him a hand say some time after work. If I am passing through your town, I might be willing to let you try out say my ECM instead of you buying one and finding that it wasn't the problem.
Old 07-18-2016, 10:38 PM
  #73
papatioman
papatioman's Avatar
Thanks for your generosity......
Old 07-23-2016, 07:51 PM
  #74
papatioman
papatioman's Avatar
Default Update
Sorry these updates are a week apart. Weekends are the only time I have to work on the car. Reassembled the throttle body with a new IAC.
First crank....started and stayed running....thought the problem was solved. Second crank.....starts & dies. Third crank starts & dies. Pulled the connector on the MAF sensor as suggested in this thread....started right up and stayed running. Left it run for a while to reach operating temperature to make sure all was well.
Left the car sit for 4 hours to cool down. With the MAF connected.....same issue as before. After I unplug it....starts up and stays running. Guess I found my problem. Thanks for everyone's help here!
Old 07-24-2016, 06:30 PM
  #75
papatioman
papatioman's Avatar
According to this article, a bad MAF sensor would cause the stalling issue I have been having as well.
http://www.youfixcars.com/mass-airflow-sensor.html
Old 07-24-2016, 07:43 PM
  #76
aklim
aklim's Avatar
I think you are right. Bad MAF
Quick Reply: Long Crank To Start...now even more.......
