Car won't start after clutch replacement
I just got a call from the transmission place that replaced the clutch on my 85 (no VATS). He says that he cannot get the car to start. He has jumped the clutch safety switch with no luck. The car will start if he jumps the starter and the ignition switch seems to be working. He has checked the fusible links but is stumped. Any thoughts???
What kind of clutch did they replace it with? Did they use the same FW? Could be a clearance issue.
There is not much that while doing a clutch would cause it. I would look for something that was done while doing the clutch. The starter needs to come off during a clutch change, so it is something to look at.
If he jumps the starter and it works, my guess is that he did not hook up the wires to the starter correctly.
Good luck.
Good luck.
Good luck.
Good luck.
Now, my interior courtesy lights do not come on when the door opens, my door hatch release switches do not work, and my power antenna does not work. I will fix these issues myself, hopefully I can find the root of the problem. But at least I can start my car and the McLeod clutch feels awesome!
Got my car back yesterday, I was told that there was a secondary switch behind the master cylinder that failed. This caused the clutch safety switch to test fine but the car not start. They bypassed that "switch" and now the car starts. I looked up and down my service manual and did not see a switch.
Check the CTSY/CLK fuse. That's the one that powers a lot of stuff when the ignition is not on, like the cigarette lighter and the interior lights.
Note that all the engine and dash and ECM grounds attach to the upper left (driver's side) bell housing bolt. It's a special bolt/stud just for these grounds. Since they took the bell housing off to change the clutch they might not have gotten all the grounds reconnected.
OP - your car doesn't have the battery "jump block" so fusible links I'd say are suspect. Do you have an FSM for your car? Do you have a test light? I'd go through the IP fuse block and confirm what is powered and when. There are some that should be at all times, some at only key-on.
The shops comment maybe hints that's what they found and maybe didn't understand the terminology! MAYBE!
I believe there's 3 fusible links from the starter solenoid itself and a total of maybe 7 on the car. I wouldn't just start haphazardly/randomly poking around.
No FSM - maybe consider a buy!!
Maybe a silly question, but does an 85 have the same 'clutch safety' switch on the clutch pedal as an 86? It's near the top of the pivot on the clutch and won't engage the starter unless the clutch is depressed and the switch is working.
Had mine not start after having the master and slave replaced on mine and it turned out to be that switch. Jumpered the switch and all is well except for being able to engage the starter without depressing the clutch.
I hope to get time this week to check out the links I do have the FSM and an Electrical Engineering Degree, but those electrical diagrams are still foreign to me. I will figure this out!
