1985 Corvette Parking Brake Problem
8th Gear
The parking brake on my '85 corvette is incapable of holding the car on an incline, or at all for that matter.
I tried adjusting the shoes outward to make them hold, but that only resulted in the shoes continually dragging. My guess is that the shoes are too worn and need to be replaced (how does that even happen... used car problems). That or there is some other problem that i'm not thinking of. Came here hoping someone could help me shed some light on the problem so it can be resolved.
Interested in hearing the fix for this because on my 85 the parking break works OK on level surfaces and if I park downhill but does no good at parking uphill.
8th Gear
Just a small update, I have confirmed that the issue must lie with the shoes. With the rear wheels off the ground, pulling the handle back does tighten up the rears enough that I can't rotate them, but its just not enough to hold the car's weight.
I have purchased some new shoes online and will begin the installation process in about a week.
Brake pads can age and glaze over too. I've seen good looking old brake shoes not hold and I assume yours has the drum brake pad type parking brake.
8th Gear
Yes you are correct the '85 uses the drum parking brake. I just found it strange that the shoes could get worn unless the PO was driving around with the parking brake. I guess it could be an age issue as well that has caused them to be unable to hold.
