Need a lot of help from you guys. Lt4 keeps throwing a code.
OK so my 96 CE Lt4 starts PERFECT when cold and runs and drives perfect pulls really well no miss or anything. If I try to start it when it's even slightly warm or hot I have to floor it to start and it idles high for 15sec. Then is fine and everything back to normal.
It keeps throwing the p0118 so I changed the sensor on the water pump with a oem one, cleared the code and 5 min later it came back. I check the harness and the sensor is getting 5.3vDC.
Is this a case of a bad ICM?
I live in NY so can't have a SES when I get it inspected which is coming up soon.
Thanks and ANY help is much appreciated.
