Changed doors
Old 07-24-2016, 02:11 PM
Gregarious
4th Gear
Gregarious's Avatar
Default Changed doors
I have a 84 corvette that I installed 87 doors on. Everything plugged in so I thought it would work. I was wrong. My door locks and hatch button doesn't work. But if I turn the key in the door in opens the rear hatch. I need help
Old 07-26-2016, 08:24 AM
WVZR-1
WVZR-1's Avatar
Received 2,254 Likes on 2,016 Posts
I'd like to think you've "sorted" this BUT the '87 later harness/switch on the door lock cylinder connector may be very similar to the hatch switch. You've connected likely just the wrong wires to the door lock cylinder harness, disconnect that from the harness in door and connect door harness to the hatch release.
Door locks? Did you maybe end up with a door from a car that DID'T have PWR LOCKS? That would seem odd but if you were just choosing connectors and components in the '87 door it could maybe explain.
***Direct fit doors might be '84 & '85 when you consider the "inner operations" to similar harness.
Quick Reply: Changed doors
