Targa Top Painted
Targa Top Painted
Good day, I have been looking for a Targa Top (Torch Red) for my 94 coupe with no success. Can a clear plastic or urethane targa be painted?
Yes but I just used vvivid vinyl artist carbon fiber looks good and $50 can get you any color you want.
Harleyman5076 (08-15-2016)
It is vinyl wrap just peel and stick than trim very easy but a two person job. Many differant brands but this is what I used. Found the small piece on ebay but look at their website too. might used their primer pen to hold better.
Harleyman5076 (08-16-2016)
Don't paint an acrylic targa top. It's easier for you to get an acrylic targa top as they work for any colors.
You can have the solid top painted. They'd bang off the metal trim and paint it and then put a new metal trim back on. No sure how easy it is to get a new metal trim. But I've see aftermarket rubber trims out there. Or they may try and reuse the metal trim.
If you use vinyl. Maybe take it to a vinyl auto shop to have it done. If you do it yourself, I'd do research on it. But I'd say probably something like car wrap. I'd get the kind that lets you easily squeegee out air bubbles. As some have air channels in the adhesive that lets you squeegee out air bubble instead of having a bubble mess for a newbie.
They've also got car wrap vinyl that doesn't do any paint damage if you later remove it.
They've got all different kinds that are easier to apply than others. The easier to apply kind is usually more expensive. But I'd stick with vinyl car wrap vs. vinyl they put on store windows.
