"Factory" Idle Speed
Old 08-18-2016, 08:20 PM
MitchV
MitchV's Avatar
Default "Factory" Idle Speed
I'm unable to find a rpm idle speed number in the FSM. My '93 LT1 runs great, idles smooth, but idles just under 500 rpm's in drive. Seems a bit low. Is this typical?
Old 08-18-2016, 08:24 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
That seems low to me too. I'd bet that your IAC valve is 10-7. Does it idle significantly higher when cold?
Old 08-18-2016, 08:37 PM
MitchV
MitchV's Avatar
It does idle higher when cold, but just about 500 rpm's. The idle also goes up a small amount when the a/c is on. Still under 500 rpm's.
Old 08-18-2016, 08:45 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Can you get it on a scan tool and see what your IAC counts are? Maybe that idle isn't too low, but my '92 (6 speed) idles at ~750 or so.
Old 08-18-2016, 09:02 PM
MitchV
MitchV's Avatar
Thats a negative on the scan tool. I may just leave well enough alone, unless it gives me drivability issues.
Old 08-19-2016, 05:09 AM
STL94LT1
STL94LT1's Avatar
A4 in gear, 550 rpms at idle.
Old 10-02-2016, 03:01 AM
larry_c4
larry_c4's Avatar
I have been having this issue with my '92 Auto as well. I have tried everything. Mine idles smooth at 500 RPM steady(in drive). Seems low to me and everyone who rides in it. Feels low like it is about to stall at red lights/ stops,but it never does. Runs great otherwise. I have Cleaned the TB/IAC, new injectors, Rebuilt ECM, New Delco Opti, plugs/wires, air filter. Been idling like this for a long time.
Old 10-02-2016, 07:51 AM
aklim
aklim's Avatar
Received 2,232 Likes on 1,943 Posts
Before you declare a problem, how about investigating if there is a problem first? What does the ECM see and not what the tach says. I have checked with the scanner and an inductive timing light with a tach. Both light and scanner agree. Car tach was inaccurate by 300 rpm
Also, what is the command idle speed? If that is set low, nothing you do can change it.
To "Factory" Idle Speed
Quick Reply: "Factory" Idle Speed
