non start when hot
Old 08-19-2016, 06:46 PM
Sid.123
Sid.123's Avatar
Default non start when hot
hello all..ive just purchased a 86 c4 glasstop....when I picked it up it started fine,engine was cold..drove about 10 minutes and stopped to refuel,after it would crank fine but not start..the guy did tell me this had happened to him once and it started ok with a sniff of easy start spray..i purchased a can and yes it started ok with a small sniff...the car run fine for the drive home about 330 miles..i didn't turn it off until I got home and again when I tried to restart it it just cranked over but didn't fire...im suspecting a fuel metering fault i.e maf sensor or possibly a fuel priming fault..anyone had this fault.will try it again in the morning from cold.i bet it starts ok.any help would be appreciated.
also when I got home the word security flashed on the dash,then the alarm sounded..im guessing you have to exit the vehicle within 20-30 seconds of removing the key?...if someone could confirm if this is normal, would be great
Old 08-19-2016, 08:29 PM
antfarmer2
antfarmer2's Avatar
I would look at the coil and ignition module. And the fuel pressure.
Old 08-20-2016, 02:28 AM
Cliff Harris
Cliff Harris's Avatar
The SECURITY light flashes if the door is open and the security system is NOT armed. It will stay on steady if the security system IS armed with the door open. The light will go out if the door is closed or the ignition is turned on.
The door must be closed within 45 seconds of arming the system (by locking the door) or the alarm will sound.
Does your fuel pump run for 2 seconds when the ignition is first turned on? If not then you might have a fuel pump relay problem.
Old 08-20-2016, 09:32 AM
Sid.123
Sid.123's Avatar
Started it this morning,started fine from cold...ran it for 10 minutes to warm it up.turned it off and again would only crank over. Will check the fuel pump relay tomorrow when I've got more time
Old 08-20-2016, 11:13 AM
antfarmer2
antfarmer2's Avatar
Why wait just turn the key on without cranking the fuel pump will run for two seconds each time if not get the relay.
Old 08-20-2016, 11:17 AM
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
Why?
Old 08-20-2016, 01:06 PM
antfarmer2
antfarmer2's Avatar
Originally Posted by WVZR-1
Why?
Both can cause a no start when hot.
Old 08-20-2016, 05:36 PM
Sid.123
Sid.123's Avatar
I'm just a bit baffled...the relay must work to start it from cold. Will check it out later and post my findings...
Removed the pump relay and checked for operation,working ok. Cleaned contacts and replaced. Fuel pump primes n runs ok..
Removed dizzy cap, rotor and module and cleaned everything up put it all back but still doesn't start when warm.
Haven't got anything to measure fuel pressure but will order dizzy cap,arm, module n leads and see if that improves things
Old 08-21-2016, 06:06 PM
Sid.123
Sid.123's Avatar
Can anyone tell me what adaptor/thread size I need to attach a fuel pressure gauge to the valve on fuel rail.. I'm looking at buying a gauge off eBay...
Old 08-21-2016, 06:26 PM
WVZR-1
WVZR-1's Avatar
Just get a "loaner" at the auto parts store to do your check and then do a buy later. If you mention wanting to likely buy AZ will sometimes order in a NEW for you to use as a loaner. I'd maybe avoid most eBay buys - way to much counterfeit stuff on the market. I'd pay maybe more locally then if I had issues I could likely be accommodated.
Old 08-21-2016, 06:32 PM
antfarmer2
antfarmer2's Avatar
Standard size like your tire.
Old 08-21-2016, 06:36 PM
antfarmer2
antfarmer2's Avatar
You need thermal grease under the module I would have it tested then install the new one right.
Old 08-22-2016, 08:44 AM
Sid.123
Sid.123's Avatar
Thanks guys
Old 08-22-2016, 07:01 PM
Sid.123
Sid.123's Avatar
thought I should add...im in the UK...corvettes are far from standard here...
Old 08-22-2016, 07:04 PM
antfarmer2
antfarmer2's Avatar
Old 08-23-2016, 03:03 PM
dclafleur
dclafleur's Avatar
Check your fuel pressure both cold and after it's hot. Also check to see if it holds pressure before you crank it, I didn't see it answered anywhere but if you give it partial throttle when it's hot does it start up? Early C4's have a cold start valve and at this point a lot of them have started to leak and that can cause hard starting issues when warm.
Old 08-23-2016, 04:30 PM
Sid.123
Sid.123's Avatar
That is a possibility however at this time I haven't anything to test the pressure. What I can say is when it doesn't start I've tried partial and full throttle thinking the same thing.
I'm sure we're in the right area though. The more I check things I keep come img back to fuel pressure.
Old 08-23-2016, 04:55 PM
dclafleur
dclafleur's Avatar
Also I saw discussion on the fuel pump relay, if the relay is bad the fuel pump still energizes when the oil pressure hits 3 psi (or somewhere thereabout) so a bad fuel pump relay would be a bit of a red herring in this instance.
To non start when hot
Quick Reply: non start when hot
