Please help
Please help
Good afternoon everybody,
today i tried to turn on my 1984 corvette...it wouldn't start, but everything else works...all lights...fans..are good, i looked at the the fuse box and the brake fuse was broken, so i replaced it with 20A fuse, and i tried start the car, it started for 5 second, then i saw a spark under the hood by the passenger side, i don't know if its a relay switch/ fuse that was blown, now everytime i try to start it i hear a clicking sound but nothing. Later on i found out that the brake fuse was supposed to be 10A...please help me.
Thank you very much
Thank you very much
Might be a loose or dirty connection on your starter. Be sure you disconnect the battery first or you will hit your head. check your battery while your in there.
Marc Michel (08-21-2016)
Still did not work....I figured since there was a spark under the hood by the passenger side...it was probably a relay switch associated with the brake fuse which I unknowingly replace the 10A fuse with a 20A on the brake slot in the fuse box...that cause the big spark...but I do not know the location or if there is one at all...please keep in mind its 84 corvette.
The fuse was in the first slot with no label on it...I have no idea what its use for...after the spark under the hood car did not want to start
Did you read battery voltagr?
did you check it? If good jump the little wire to the big one on the starter if it cranks then have your starter rebuilt best to use a remote switch to do this for saftey. If it cranks you can turn the key on and start it and drive where you need to.
