Tuner Pro RT not connecting 93 LT1 stock
08-26-2016, 11:25 AM
Hi guys...anyone using TunerPro RT to data log? Everything downloaded and cable good. When connecting to car, flashes from connect to not.
I don't plan on using this for tuning, just want to get a reading on engine data.
08-26-2016, 08:52 PM
Go into the setting and click "disable ccm handshake" and "disable digital data refresh"
08-26-2016, 10:08 PM
How do I locate those? Sorry, really new at this.
08-27-2016, 08:40 AM
Sorry, it's been awhile since I've data-logged anything. I think I confused Tuner Pro with Datamaster. My earlier advice isn't going to help you.
08-27-2016, 09:22 AM
Thanks for responding. I did try to load Datamaster, but found they have stopped supporting GM cars.
08-28-2016, 02:56 AM
08-28-2016, 10:16 PM
do you have the ADS or ADX? I can correct it for you to connect to your car
08-29-2016, 09:17 AM
Quote:
Originally Posted by
-=Jeff=-
I have both, is the ADX the one you need? Can I copy and paste the file here or would it be easier to send it to you via email?
Thanks, I've been working with this for a couple of week and just can't seem to make it work.
08-29-2016, 09:22 AM
Sent you a PM with my email.
There are a couple things I want to check. I fixed one for a friend with connection issues for his 1992
08-30-2016, 01:17 PM
-=Jeff=-
Fixed...Thank You!
08-30-2016, 01:58 PM
jph46
Fixed...Thank You!
What was the issue?
08-30-2016, 02:00 PM
jph46
Fixed...Thank You!
It is attached in a Zip File here as well..
08-30-2016, 02:01 PM
JimLentz
What was the issue?
there were no commands to silence the CCM ( or start it back up)
The CCM needs to be silenced to datalog correctly
The following 3 users liked this post by -=Jeff=-:
02-11-2017, 10:05 PM
-=Jeff=-
I was having the same problem and extracted this file-It Now Works!! TunerPro RT V5 on Windows 10.
Thank you! Thank you! Thank you!
Steve
02-13-2017, 12:48 PM
-=Jeff=-
If you're ever in the Downers Grove area I owe you a beer, root beer, coffee or whatever you drink. Thanks Jeff!
02-14-2017, 09:58 AM
02-14-2017, 06:16 PM
-=Jeff=-
I know this is an older post, but Jeff's statment is very true.
