No power too both sides open/lock switches 1984
Was working on drivers side replacing worn open/close switch
Had too cut wiring, orange-blue=black
Grounded one of the wiring causing no power too passenger & drivers side open / lock switches
Book states the cavity that says Hatch controls drivers & passenger sides
Have Power too all other fuses except the cavity that says Hatch . DEAD
Is there an inline fuse someplace else ?
Does that one have fuseable links behind the battery?
First main links are at the starter on an 84 (also at the battery), none behind the battery.. Second, what book are you using?? My FSM shows a 35 amp Power Accy. circuit breaker and the ctsy fuse providing power to the door locks circuit. I'd question the no power to the hatch fuse, as it's powered by a fusible link that powers several other fuses..
If the CTSY/CLK fuse blows, you will also loose everything else that is normally powered when the ignition is off.
Ccrazor's reference to the 35 A circuit breaker is for the Door Lock Relay circuit, but that's not in the door panel. That is behind the center information panel.
The lesson here is to always remove the negative battery cable when you're doing any electrical work. The other lesson is about: too, to, and two.
Thanks for all your responses. Thought I had checked all the fuses, one got by me.
love easy fixes
On my 96 blazer I went crazy trying too locate a flasher . Seems they had a number of flashers buried behind ash tray and I had too take apart that area too locate. Thankfull too forums and utube too help . My thinking was okay another buried inline fuse, reaching out too vette forum.
THANKS AGAIN
love easy fixes
THANKS AGAIN
