Remove Front Sway Bars - Yes or No???
#41
Pro Mechanic
Hey Dave, that's O.K. I'm used to it. Lots of people resort to insults, sarcasm and drama when they are confronted w/facts and solid evidence. You asked me;
"what is the other car at any price point that uses it any price point?"
So I did. I gave you 4 legitimate examples w/o any effort at all. You come back w/a horsesh!t response.
I say someone needs to run a test. GM may be wrong about their claims, but I doubt it. If all that we had to go on was a "marketing blurb" about the springs...yeah, I'd be skeptical. But the chief engineer of the car wrote in his book (after retiring from GM) about this effect from the spring. He's an engineer. Is THAT "engineering and logic has left the room", too?
#42
OTOH, a solid axle car sends it transmission output to an axle that is not solidly mounted to the frame, but instead is effectively solidly mounted to the road. Since the frame is only connected to the diff by compliant springs, the engine and frame and the axle can't spin around the driveshaft (because pavement), then the engine tries to spin the whole frame around the drive axle. The only thing that keeps the car's body from spinning in endless barrel rolls is that the springs eventually resist the torque enough to arrest the roll and/or the tires run out of traction. If you took the springs off altogether and hung the car from a crane by the spring attachment points with the brakes applied to keep the tires from turning (or the ring gear welded to the pinion so it wouldn't turn), the body would endlessly spin around the driveshaft axis. But...what if the axle were solidly mounted to the frame with no suspension at all. Then what would happen if you hung it from the crane again? Thing about that, and then consider that an IRS is effectively the same thing because its diff is also mounted solidly to the frame without a meaningful suspension.*
*Save for some rubber bushings, that are not consequential to this matter and can be eliminated for more race-oriented use anyway.
To the OP; drive sensibly without a front sway bar and you won't notice its absence.
#43
Pro Mechanic
^Worded much more concisely than my post. Well said.
My memory was a bit off; there was no reference to the Camaro, but this is straight from the horses mouth; the Chief Engineer of the car. One might claim that this is marketing rubbish. Let's consider the source; a book published in '02, by the engineer of the car. The guy is writing about a car no longer produced by the company that he no longer works for. In addition, Dave has no problem disparaging many of GM's practices throughout the book....including the Targa top (which BTW, didn't come from "styling"). I'm just not seeing where "marketing" would come into play here. Guys, I think the McLellan was telling the truth.
#44
Yeah, I think I'm going to end up standing corrected here. I did some thinking and found an interview with a guy from Pfadt. Ironically, I think he got it exactly backwards, but there is a way the transverse leaf could resist roll by reducing suspension independence. It could not happen if the spring were clamped solidly across the entire 18" center section. But because it has freedom to flex in between the two mounts, I can see how moving one end of the spring down might move the middle portion up, which could then move the other end downward somewhat. That would provide some measure of roll resistance exactly the way a sway bar does. Whether that is a significant portion of the roll resistance is open to question. Also, if this extra variable is deemed a problem, then the easy solution would be to fabricate something to clamp the spring all the way across the 18" center.
It's still worth modeling, but I suspect that will demonstrate that the effect is real. To find out its significance would require a real Corvette with a scale and a calibrated way to weight one end down a measured amount. The question would be: if you move one end of the spring down by 1" (and therefore put a known amount of force on the spring based on spring rate), then how much force does the other end exert onto the scale? Now I'm curious. Also curious is how the effect changes by altering the spacing of the mounts, and by altering the dimensions of the spring in the middle section (e.g. tapering the thickness or the width up or down).
#45
I read about the targa top deal on a Corvette forum though not sure which one and the quote was credited to Gordon Killibrew(sp?) and have experienced the difference in mine with top on and top off so they lost the rabbit somewhere in chassis design. I personally suspect the large open area under the floor pan with nothing in shear. Adding the roof closes the box and adds a shear plane. I think if they had bonded a rigid floor pan to the frame including the front and rear bulkheads it would have made a large difference but no doubt out of the budget.
From my experience with everything from NASCAR modifieds and road race cars high roll stiffness comes with a price tag of needing a smooth track surface with little compliance for any sort of bump or void. Watkins Glen is a good example as last time I was there to work on a car 90% of the track was very nice but the hill after turn one was a challenge. as pretty rough. I have only found 2 times to limit suspension travel the first a ground effects car that requires strict clearances and the second one with poorly designed pick-up points with bad camber curves and bump / roll steer. Attached is a link to what claims to be wheel rates for various years a sub models of C4 production and sure looks like they were all over the place. I am sure if I were to race a C4 or any other car I would start with chassis stiffness and once fixed move on to suspension geometry and pick-up points. My opinions free and do with them what you will...
http://www.netmotive.net/articles/hib/c4/sustunch.pdf
#46
Im thinking that if GM had the maths on how much difference leafs make to anti-roll they would have been telling everyone for years to defend their decision, but we still rely on urban myths to keep it rolling. They probably didnt have the time or money during c4 development to test the theory. So unless someone has empirical data proof, the jury is still out on this one ?
So as far as the engineers saying that the front leaf stiffened the front end (and required less roll bar) as long as it was clamped 18" apart, Im thinking that clamping the spring between the 2 chassis rails is introducing a chassis stiffener and thats how it works, as opposed to being a defacto sway bar ? Maybe needs a minimum of 18" to be stable under roll and weight transfer ?
The reason Im thinking this is as a result of making a front camber bar and the result you get from tying those 2 front chassis rails together. If you stiffen a chassis you need less roll bar.
#47
Like I said, I think it would be trivial to test this idea, and I'm 100% sure that GM did test it. What their exact findings were is another story.
#49
The way the spring is clamped by two straps, it has multiple degrees of freedom to move. It could not provide meaningful chassis stiffness because of that.
Like I said, I think it would be trivial to test this idea, and I'm 100% sure that GM did test it. What they're exact findings were is another story.
#50
Pro Mechanic
Read on, if you'd like...about the structure, and how the roof plays into that;
In the space between the two mounting points, the spring is free to move...and it does move in that space.
#51
Pro Mechanic
That would provide some measure of roll resistance exactly the way a sway bar does. Whether that is a significant portion of the roll resistance is open to question. Also curious is how the effect changes by altering the spacing of the mounts, and by altering the dimensions of the spring in the middle section (e.g. tapering the thickness or the width up or down).....I'm 100% sure that GM did test it. What they're exact findings were is another story.
I did a little more looking and found this, very specific data about both the springs contribution to roll stiffness and the ability to tune that by changing mounting point locations. Read on....
#52
Attachment 48018936
Attachment 48018937
Attachment 48018936
Attachment 48018937
BTW, that book by McLellan looks fascinating. I need to get it. Is it Corvette from the Inside?
#53
Back to,the op's original question, I drove my C4 for years on the street with no front sway bar and drag shocks. It was a street/strip car back then and the handling was actually very good thanks to the Z51 springs. I didn't enter any autocrosses, but it was very safe on the street. I had no issues.
Wheel Stander (09-17-2016)
#55
I did some minor corner balancing on mine a few years back. I didn't think it was that bad to do. Me in the car with a full tank:
#58
#59
Originally Posted by Wheel Stander
Thanks for getting us back on point. I never intended for my inquiry to result in a prolonged debate on the physics of vehicle suspension configurations. Oh well, I guess people sometimes just get carried away.
#60
Pro Mechanic
Both books that should be bought w/any C4 purchase, IMO. "Corvette form the Inside" is "better" because you get so many details from "behind the scenes" From Dave himself. Invaluable, IMO. In "The Newest Corvette" is "better" because there is more technical detail about the C4 itself, such as the frame structure, etc. More of that book is dedicated to technical info, where as Dave's book gets more into politics, motivations...etc. The way Dave words things make implications that allow you to fill in blanks about certain things. Good stuff.
