rear end pinion bolt removal?
Thanks for the details!
And so far it has been pretty solid after the second rebuild.
I never had the return springs in my trans, but i did install the return springs and the drum check valve supplied in the transgo 700p rebuild kit.
i also installed the larger reverse boost valve along with the .500 boost valve.
Kolene steels and red clutches throughout.
oem 5 pinion front and rear along with the carriers, front and rear sprags replaced with the better later parts..
Only complaint so far has been a pretty violent 3-2 and 2-1 manual down shift, like i have to make sure my rpm is under 1500 or my tires screech and the rear fishtails.
Its also a little rough when accelerating slowly and up shifting.
Whats nice is a manual up shift in wot
And for the pump, the wear marks were at the top of the rotor.
Update on this, i was finally able to get the pinion bolt removed.
I ended up picking up an aircat 1150 impact for a about $130, listed as used on amazon.
I have a 8gallon harbor freight borrowed from my father in law while i save up for that quincy two stage.
The impact is rated at 1100ft lbs in reverse, it zipped that pinion nut off like it was nothing!
good to hear. i know what u mean about saving for the two stage!
Someone in this thread mentioned "crush sleeve". I don't think Dana axles use crush sleeves. I know the 44 doesn't, but the OP has an automatic. Dana's have shims under the small pinion bearing to set pre-load. The nut is torqued to "a hell-of-a-lot". Not at all like a 10-bolt in a Chevelle.
You mentioned Typhoon/Syclone sometime back in a thread. Do you still have either?
