Clunking noise
Clunking noise
Hello to all this is my first post as I just got my first corvette yesterday. It's a 1992 6 speed all stock. Drove 6 hours to get it and I can't complain a bit I love the car. Anyhow I noticed once I got back to Louisiana and got back on these horrible roads that when I hit bumps even the littlest ones like driving down a gravel driveway it makes a clunking noise and like metal and metal just hitting. i think that it just needs new shocks but is there anything else it could be? It's obviously coming from the suspension, sounds like front and back. Thanks for any replies
Welcome to the forum. Pick it up and wiggle push pull and shove. Look at the bushings too.
What you described could be anything from a bad exhaust hanger bracket to a loose shock mount.
I suggest if you don't want a million shots in the dark to your issue that you may want to assist all of us by narrowing your problem to a generalized location. Front, rear, left, right, inside, outside, underneath, topside?
Just trying to alleviate some of the frustration you will get by a million different thought on your issue.
Could be anything to everything. I really wouldn't drive the car anymore till it is put on a rack by a qualified mechanic that will check everything. You really don't want something breaking apart at 70mph. It can be a LONG day.
Sorry for the vague description but to narrow it down a little more the car doesn't vibrate going down the road or make any noise just driving it's only when hitting bumps. It seems to be coming more from the passenger side. I checked the a arms and steering components and nothing is loose in that area but tonight I will get the car lifted up and check for loose shocks and that sway bar. I drove it 500 miles Saturday with no issues major issues other than that racket when I hit bumps
There again you know nothing about the car so we don't know what the moron aka Previous Owner did. Sounds safe from what you said. Could be the shock bushings are shot. I assume the shocks are not leaking? Hopefully they are not empty.
Have a look at the front brake pads, do they have the small spring clips attached? Without them the calipers will make horrible rattle noises.
http://www.parts123.com/corvettecent...050f&ukey=8632
Hi
[QUOTE=gerardvg;1593274591]Hi
Too follow up the problem ended up being those brake pad clips gerardvg mentioned. Autozone had them so I replaced them and no more problems. Thanks! Now on to the next little issue which is the AC lol but I will search other threads for that!
[QUOTE=cole198;1593290099]Didn't fit or what? Sounds odd
clunking noise
