88 coupe rear defrost wire
Hi guys.
I own a '88 coupe and one of the rear defrost wires that was soldered to the hatch window has broke off. I have tried soldering it and even used tin flux. Nothing I do will work on it. What do I need to use to attach it?
Also since I bought it the coolant temp reading on the dash has never worked. Always says low. I have replaced both sensors on the block. Still nothing. I pulled the ecm out and the po had spliced in a new wire directly from the ecm to the sensor on the pass. side of the engine block. The original yellow wire was spliced at the ecm. The yellow wire that goes into the harness under the dash wasn't spliced into the new wire so I tried that. It still doesn't give me a reading. Now after about 20 min. of driving the check engine light comes on. The car seems to run rich also. So i'm wondering if since there isn't a temp reading that the ecm is choking the car making it run rich?
Any help would be greatly appreciated. Thanks!
thedoc1876 (10-18-2016)
Yup that looks like it will be perfect. Thanks!!
Also my car has the notorious blowing hot air all the time problem.
I have the replacement clip for the hot/cold door under the dash however that looks pretty tough to get into. anybody have a detailed way to replace it?
1. Have the car scanned for the CEL codes and react to the "run" issues first. I suggested a scan because if you've multiple codes a scanner works much better than a manual check jumpering the ALDL (I think anyway so ..)
Do you have the FSM for the car?
There are no TEMP sender/sensor for ECM or TEMP GAUGE on the BLOCK.
The YELLOW that you mention at the right side of block isn't the CTS the ECM uses for signal. ECM - C10 CTS wire is YELLOW but it's information is from the CTS front of the intake. The sender in the RH Cylinder head should have a GREEN wire that is used for TEMP GAUGE in cluster. Look for maybe a GREEN wire dangling in the vicinity. A "dangling" disconnected GREEN I believe will give you what you see.
CTS for the ECM is front of intake below throttle body. Rear of RH cylinder head for temp gauge cluster.
The rear defrost I'd think of no importance at this time.
You've mentioned much that isn't correct here so I'd think you sort it out in order of maybe importance.
Ah ok. I'm just going off of the "hack" job the P.O. must have done previously.
Thank you for your response. I will get started on it immediately.
Here's C100 PIN-OUT Many struggle with the PIN-OUT orientation
Hi guys.
thedoc1876 (10-21-2016)
not sure where some of this thread is going, but addressing the broken defroster wiring tab, i did have success re-soldering mine. it's been around 15 years now, and i don't remember the details, but i seem to recall using a weller soldering iron with 60/40 rosin core, and i reattached it to the farthest or end solder pad. it appears that OE used some sort of conductive adhesive similar to the frostfighter link, and was attached between two solder pads.
The braided copper is a very good heat conductor. It takes a LOT of heat to solder the wire to the braid. I used a 100W soldering iron and still had trouble getting it hot enough.
I'd search this wire bundle looking for the DK GREEN before attempting to get into the C100. If you had trouble locating it in the bundle you might find it coming out of the C100 and just splice.
Attachment 48028714
Attachment 48028715
Attachment 48028714
Attachment 48028715
Thank you so much for your detailed advice. Spot On!!
