Am I dumb, or is something wrong?
I consider myself a half-way decent handyman, and if i can't figure it out Google hasn't failed me...until now. I recently bought a '96 LT4 and in the process of making sure everything is operating to the best of it's ability I was flushing the coolant system. When I opened up where I thought the thermostat was, I found nothing. Searching the internet has yielded no help. Did the previous owner neglect to have one in there, or i just not looking in the right place? The car wasn't running hot. Thank you in advance.
Yes that is where it belongs. Get a good quality stat and put it in. They are specific to the LT motors, so don't let the part store guy sell you one for an older car. It will have an extra disc on the bottom that seats on the hole in the bottom of that cavity. Good choice of project cars!
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Ooo-oooh a t-stat thread in the making!
If you remove the t-stat it will run cooler......
Thank you everybody. I auto zone is getting a 160 degree thermostat for me tomorrow. I just needed to make sure I wasn't taking crazy pills.
Pick up some antizies too.
IMHO, a 160 'stat is too cold. The LT engines are designed to have be a 180 or maybe a 195 'stat. That helps with faster warmup and to reduce emissions.
I appreciate all input. I opted for the 160 because I live in the desert where temps get up in the 110-120 F range. Went for a lower temp so it opens sooner. I believe that will keep the motor running about the 180-190 range during those hot days. I'd love to hear thoughts on this. Like I said "half-way decent handyman". hahahha
Pro Mechanic
I'm that "boat guy"...what's wrong with that used as an example? It's a domestic pushrod V8 engine that works very hard all the time, runs "too cold"...yet some how, they last "long enough". Seems like a point/example worth sharing for some perspective, to the 160* alarmists.
Where did you read that? I've "read that" (for years) too...unfortunately I've only "read that" on web forums -in spite of a good bit of searching the topic. Never seen anything that would be what we call, a "credible source". I think it's lore and I readily welcome some real, objective documentation on the matter. Otherwise, we're just regurgitating BS from a previous web poster's opinion.
One reason I don't think you can compare boat motors is they run at a much higher percent at 100% throttle which increases cylinder and cylinder wall temperatures more relative to coolant temps.
Pro Mechanic
I know I read this in either Hot Rod or a similar magazine some years ago. The thing I don't know is how applicable that might be to modern engines and modern oil. The original article I read looked like this one.
You make an interesting point about boat cylinder temps... but I've ran cars at "too low temps" too...and they lasted longer than long enough.
Well that link is something. Thanks for posting. Did you notice that the area of the graph is where the curve has almost flattened out? So what would that diff in wear mean, in real life? Probably not nearly as much as other factors such as PM regiment. Where did he get his data? The graph? Years of research"? I know you don't know, it's a rhetorical question b/c what I'd really like to see is the actual data from these or any tests.
Pro Mechanic
I agree 100%. I question that very thing, when ever this is brought up and (besides my boat) here is a reason why; One of my "cool running cars", I sold it at 200,000 miles to a friend who drove it to 245k where it finally blew a head gasket. I lost track of the car beyond that, but a head gasket failure wasn't "worn bores", rings, etc. and when I sold it, no oil burning, good gas mileage, etc... So if those bores were wearing at "twice the rate"...then my take away would be that the wear rate is SO LOW...it really doesn't matter. Thanks for providing that link though. It is weird that for as many claims are made about the topic, such little concrete documentation is readily available.
Totally. That is one BIG question. What is the real meaning of the claims?
Page 53 here is interesting, but the wear rate seems way too high to me. 160 degrees looks to be around .001 inches in 60 hours, which I find suspect, of course there is a lot of information missing. Were these new engines or what state were they in?
