What would cause the
Dash brake light come on for about 2 seconds then go out - just cruising down the road - has done this twice today - fluid level is ok - brakes are good - firm brake pedal - so????
If I use the e-brake on my '85, it will do that until I get the handle back down just right. I just keep pushing the button while jiggling the handle and eventually it will go off and stay off.
I had to tweak the microswitch on the parking brake on mine after I got it. The light was on 'a lot' of the time. It is a copper arm so be gentle but with a little additional bend in it, it's off 'most' of the time when it should be off.
No year given, so does that light also indicate possible a/s problems?
Zen Vet Master Level VII
