Rear tire issues
8th Gear
Rear tire issues
[FONT="Comic Sans MS[/FONT]
Greetings!:
I have a 1984 Corvette coupe and it goes through tires particularly in the rear at least once a year. I am using the 255 50zr 16, BF Goodrich, which is about the only tire you can find for this veto, I am not driving crazy, but it sure wears out tires quickly.
Thanks so much for your advice, it is always top rate and the best!!
--jw
Greetings!:
--jw
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
As long as those tires are wearing evenly, seems your driving is about par for a Corvette.
Greetings!:
--jw
Greetings!:
--jw
BFG only makes a soft tire in that size, You could try a different brand with higher tread wear number something over 300. VR & ZR series tire normally wear out in 20-30k
I agree on possible alignment issue, and/or dragging brake(s), and/or low tire pressures... don't want to overlook the obvious.
^ yes this would be very good information for the thread. OP, how many miles are you getting out of your rear tires before they need replacement?
