Crate Motors for the 1985 L98
Before we go there, have you run a compression test to see if there is any cylinder issue?
The last time I ran a compression test, 8 years ago, the cylinders were within spec with not much variation. It has a bad exhaust valve or two now so I figure it's time for something new. I don't want to do valve with worn rings, etc at this point.
I'd do a leak down test and see if there is a problem. If the valve is bad, it is a lot less than a new engine. OTOH, if the rings are bad, that is a different story
Here you go.
https://www.summitracing.com/int/par...sp04/overview/
Have a local shop do the heads and run all the sheet metal and manifold base through the parts washer. I would price out what it might cost to go this route just for a base line.
You can rebuild your engine for far cheaper, and have a nice solid combination when done.
I would rebuild your factory engine, use the '91 D-ports and put a small cam in the car. This would be a nice, extremely fun combination in your '85 vette!
He priced it out at $5000. I suspect they were dumping all kinds of expensive parts at it.
Received 3,043 Likes
St. Jude Donor '05
chevroletperformance. com has a number of options
goodwrench crate motor Jegs and Summit carry
5k gets you a basic no frills 383 all day its a matter of what to do with your 85 ecm or tuning few guys here know them well if its cost effective doable or not
GM does sell it in shortblock form so you can use your heads to bump up the compression some may as well sneak a small cam in watch the overlap with the 85 ecm.
Bet it outlasts about most crates out there
The "mine was cheap and happy...its bulletproof no problems" well report back in 30k, 50k mi not 3000
New 4 bolt main block
Using your heads will bump up compression some
Sneak a small flat tappet cam without aggressive lobes ought to play friendly with the 85 ecm and no worry about flat cams. I dont buy the oils that bad when you ask a FT cam to do a rollers job they just wear quick. That and many cores out there are just plain crap metal rollers arent exempt either. Stick with the little guys there are some older designs that run great and last forever. Get some good quality lifters they are only $40 more than the no name cheap stuff.
#33
The $5000 was labor costs and the rebuild costs (misc. parts, machining, etc.). I was supplying the big ticket parts. That was to rebuild my duplicate 85 block I had, add the 91 heads, intake and headers, remove the old motor and install the rebuilt motor into the car.
#34
How much for the rebuild only? The rest you have to do anyway
#35
Now I understand. This was for a turn key package. Basically most of the cost is labor. For some reason, I thought you were going to do the work to remove and install. The cost seems reasonable now.
#36
#38
I'm no stranger to engine builds and installs. I lost my garage and space thanks to a nasty divorce so in order to do this rebuild in the near future, I may have to farm it out. However, my father-in-law, who's also a car guy, he has classic Fords, has offered his assistance and the use of his garage, tools and lift so it looks like we might be doing the ATK short block someone recommended with my 91 heads. If I play my cards right, the whole build should be around $2k with me and my father-in-law doing the labor.
#40
I already thought of that and there's no way that I am paying more than what my C4 is worth to get a new motor done. My wife is begging me not to sell the car but if I find a nice LT1 powered C4 for under $8k, its a done deal and I've already found 3 of them.
I saw your comment about the wife begging you not to sell... and then the comment about a nasty divorce. Either your ex-wife has no say so in the matter, or you move quickly and are already remarried.
Nonetheless, if you have the skills supply your own labor. You can do a basic rebuild for cheap if basically reusing OEM parts and supplying your own labor.
And a rebuild can easily exceed the value of these old C4s....
