Best aluminum parts cleaner?
What's the best aluminum parts cleaner, for stuff like the plenum, runners, Top of intake manifold, etc.? As you probably know, the inside of those runners and plenum are funky!...So I'm looking for the best CLEANER without discoloration, as opposed to any sort of high luster polish. I don't plan to polish them at this stage of the game. What's your experience? What works and doesn't work? Thanks...
racerseks (12-09-2016)
I have read on some threads on this site about using an aluminum etching spray then a satin clear coat. I have used greased lightning diluted from concentrate to a pretty strong solution with some luck Simple Green is to be avoided as it somehow weakens the aluminum. Thinking out loud it seems like a quality wheel cleaner might be useful as well but never tried.
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
You may use Simple Green on aluminum without fear. If Eagle wheel etching cleaner doesn't weaken aluminum (and it doesn't), then SG won't weaken aluminum.
I worked for 30 years in an aerospace company that chemically mills metals including aluminum. We typically acid etched aluminum until 80% of the material was gone. The remaining aluminum maintained its full strength. If Simple Green doesn't hurt your skin, it won't hurt aluminum.
Personally, I'd use Simple Green and those small, toothbrush-like stainless steel brushes that are so handy. This will clean up the aluminum and leave a natural finish.
racerseks (12-10-2016)
Pro Mechanic
Stuff works awesome.
for those of us in canada the equivilent is called aqualum. available at napa. works awesome
Spray it on, give it about thirty seconds, and scrub lightly. I used a dollar store nylon bristle kitchen brush.
Attachment 48044032Attachment 48044033Attachment 48044034
Regular cleaner is detergent of some type and strength. The diff is that the "etching" isn't detergent, it's acid and produces a chemical reaction with the aluminum, literally eating away the outermost layer of metal, revealing metal that has never seen air before -and it's spotlessly clean as a result.
Cool good to know
I used carb cleaner on the inside of my plenums and a brush, Walmart window cleaner is cheap and cleans almost everything, spray it on and let it evaporate, make aluminum really nice. Used to use Simple Green but this is cheaper and works better...
