C7 hood vent on a C4 - anyone done it?
I think your mock-up will work very well. Just a thought: you might be able to save a ton of work and under-hood complication by not making a fully-enclosed and sealed duct, but instead just using a guide at the bottom of the radiator to deflect air toward the hood vent. An example is here, starting with post #876. Note that they didn't actually seal the system - they just used a sheet-aluminum deflector at the bottom rear of the radiator to guide air to the twin ducts in the hood. Terry (the originator of that thread and car) has access to some very high level motorsports aerodynamicists, and I'm guessing it was their suggestion that he could achieve 95% of the airflow with 10% of the fab work and materials.
ETA: On an LT engine with Opti, I'd probably extend that deflector over the front of the engine to very near the top of the hood, just to shield the Opti from any water that makes its way in through the vent.
Gareth (01-03-2017)
Matt, we also did similar work with a rolled radiator, ducting and hood venting on an infamous C4 that runs in the Texas area. Unfortunately, we can't show pics, as the competitor likes his privacy. It worked great.
Hey Gareth your cars looking good! How's that 427 running. It was cool you made it over to here to help put the engine together. That has to be a rare find in England... I can't imagine there's too many 427 C4 Corvettes over there. It's a Badass car!
It's running sooo much better after I found the earth fault. The Alpha N program I had done in the UK now works fine and looking at the FAST data logs the O2 sensor / Lambda readings look good, certainly for normal driving.
Took the car out in late December, I think the car has all the power I will ever need- with wet roads every time I looked at the gas pedal the tires span!
Just tidyng up to do now... and enjoy it! Really hope to get back over to the US with the family some time, my 3 year old is a big Van Halen fan so we can all rock out together!
