Door Glass adjustment
Old 01-24-2017, 12:31 PM
wzschirnt
wzschirnt's Avatar
Default Door Glass adjustment
Hi,
93 Convertible
I had all new weatherstrip put in (by a Corvette shop) and now wind noise. Sounds like from the windshield pillar area on both sides.
I can press on the rubber and it affects the amount of noise. Maybe the replacement rubber is just a little thinner than original(?).
So, is there an adjustment for how far up the glass goes before the motor shuts off. Trying to get the glass to press a little harder into the weatherstrip.
Any thoughts
walt z.
Old 01-25-2017, 04:51 PM
VikingTrad3r
Oil Producer
Support Corvetteforum!
VikingTrad3r's Avatar
Received 2,262 Likes on 1,446 Posts
charliet615 (01-25-2017)
Old 01-26-2017, 11:03 AM
wzschirnt
wzschirnt's Avatar
Hi,
That link is 'spot-on'!!
Thanks.
walt z.
Old 03-30-2017, 01:25 AM
GREGGPENN
GREGGPENN's Avatar
C4 of Year Winner (appearance mods) 2019
Did the adjustment cure your problem?
Old 03-30-2017, 01:05 PM
wzschirnt
wzschirnt's Avatar
Sort of. I didn't attempt the adjustment myself; rather I took back to the Corvette shop (I figured they know this stuff better than me) a couple of times. A combination of aftermarket weatherstrip and a myriad of adjustment opportunities makes for a tricky job.
It is now better than it was, but not like it was before I started on this journey. Good enough for a 25 yo convertible for me.
So on to the next project.
walt z.
Old 04-04-2017, 09:38 PM
Komiller118
Komiller118's Avatar
so which way do you turn the screw to adjust the tilt and the height......????
Old 04-04-2017, 09:48 PM
billschroeder5842
Zen Vet Master Level VII
billschroeder5842's Avatar
Received 1,140 Likes on 845 Posts
Where in the metroplex did you take it? I'm looking for a good Corvette shop.
Old 04-05-2017, 11:16 AM
wzschirnt
wzschirnt's Avatar
Mid-Cities Classics in Hurst. Long-time friend owns it. Lots of Corvette and other 'classic' projects over there.
walt z.
To Door Glass adjustment
Quick Reply: Door Glass adjustment
