Electrical problem - Please help!!
Old 02-19-2017, 10:36 AM
dm_c4
dm_c4's Avatar
Default Electrical problem - Please help!!
Hello guys,
I have some electronic problem on my 1988 C4 and dont know any further about it
It suddenly occured and shows the following:
1. Anti-Lock control light is blinking while driving
2. Turn signals work when engine is idling and car stands still, but blinks very very slowly, about once every 3-5 sec.
3. When driving turn signals don't blink at all. When I stop the car then they do, again very very slowly.
4. When turning on headlights or pushing horn button while driving the engine starts to stutter. When engine idling I can turn on the lights without problems.
5. Fuel level shows full altough tank definitely not full. The shown range can be true (is not the range at full tank level).
So what could be the problem? Does anyone have an idea? Maybe the generator is broken? Or some elec. short? But where?
I have no idea.
Thanks so much for any help!
Old 02-19-2017, 12:23 PM
antfarmer2
antfarmer2's Avatar
I would start by testing your battery and alt and clean all connections.
dm_c4 (02-20-2017)
Old 02-20-2017, 02:00 PM
dm_c4
dm_c4's Avatar
Thank you
Yes maybe I should start with this. Seems like no one has an idea anyway
Old 02-20-2017, 02:57 PM
N42375
N42375's Avatar
I agree with Antfarmer. The problems you describe would indicate a voltage fluctuation. Low voltage would cause the directional signals to blink slowly. Do a load test on the battery,then check the voltage output at the alternator and then the voltage regulator. Don't overlook your ground wires. Corroded wires can really have you chasing your tail to find the problem.
Old 02-26-2017, 10:27 AM
dm_c4
dm_c4's Avatar
Today I spend some time about it but couldn't get any further.
1. I installed another battery and checked all connections to the battery -> problems persist
2. checked battery/ alternator following this instruction: http://www.rockauto.com/Newsletter/a....html#tomStory
-> not really a result
-batt has 12,4V
-with engine running 14,8V
-enigne off and ignition on 11,90V
3. adding a 2nd batt with jump start cable OR my other car (has 110amp batt) -> no change
When engine off turn signals are blinking veeeeery slowly, when turning on head lights turn signals nearly stop blinking.
The only thing was that when I added another batt with jump start cable then the fuel level shows correctly (reserve) instead of full.
So I have no idea. If there is some short cut where should I start? There are probably hundreds of cables on the car. But where can come a short cut from when the car is sitting around?
Any further help is very much appreciated! I am totally clueless
Old 02-26-2017, 12:00 PM
mickey5
mickey5's Avatar
Sounds like a corroded ground. Dampness is your enemy.
Old 02-26-2017, 01:43 PM
dm_c4
dm_c4's Avatar
Hi mickey5, do you think of a specific wire that I should check? There is one ground cable that goes directly from battery minus pole to the frame. Maybe I should renew it and look if this helps
Old 02-26-2017, 01:52 PM
dm_c4
dm_c4's Avatar
And one question about the voltage regulator.
Is this inside the alternator? Could it be the reason also if the descibed problems occur when engine is NOT running?
What are these boxes behind the battery? (shown in this pic http://s1207.photobucket.com/user/wa...l?t=1378503641 )
Old 02-26-2017, 02:53 PM
ctmccloskey
Support Corvetteforum!
ctmccloskey's Avatar
Received 1,104 Likes on 876 Posts
Default Slooow signals in an 88 C4
Hello there,
I have a 1988 C4 coupe and it sat for a while. After trying to wake it up I found a huge number of issues and most of them were electrical.
Being a Battery specialist I would right away say that 11.9 with ignition on sounds really low. Your open circuit voltage looks okay but I would strongly suggest that you charge this battery up with a minimum 15 amp rate just to give it a good equalizing charge. Batteries that sit around can sometimes develop stratified electrolyte. When the electrolyte gets stratified it will appear to have a good battery when you only have a fraction of its capacity. A good solid charge will usually take care of it for you. Now, on to the fun part....
I would get a multi meter and start looking to be sure that your grounding system is working properly. With the car "off" try this. Holding the ground wire from the meter (black) on the battery (-) negative terminal take the red positive (+) wire from the meter and read the voltage at the output terminal on the alternator. You should get the exact reading that you got when you tested the battery by itself. You should see full battery voltage.
Then with the meters red wire connected to the positive (+) side of the battery connect the ground wire to the engine block on solid metal. When you do this you should also see full battery voltage.
These tests are the very first I would perform before diving into anything.
Behind the battery is a post with several wires connected to it. This is where the battery supplies power into the (most of the) rest of the car. Remove the terminals and clean each one of the ring terminals so they are nice and shiny. Using a tiny pin and my meter I verified that each of the fusible links were good.
In my case the corrosion was the absolute worst at my fuse block, it appeared okay to the naked eye but my fuses were not conducting any current. I removed all the fuses and replaced them. They all still had the internal wire intact but they did not conduct any electricity, weird.
So after using Electrical terminal cleaner with a small file (old points file worked great!) or a piece of Emory cloth I cleaned every connection and the fuse holder blades. Some of my fuses had a white residue on it like aluminum corrosion and it was found in the fuse block as well. After installing new fuses the car suddenly woke up and where there was no power before I now had 12 volts. I replaced the circuit breakers as well, just to be safe.
It appeared that water (or lots of moisture) had got into the fuse block area somehow and started most of my troubles. Check for voltages at the fuse block to see if you have the same problem.
I bought a tool which I have found to be "The Tool" when I am trying to solve problems like yours. It is called a "Power Probe IV" and it should be included in every Corvette owners tool box. it will help you find and solve all the electrical gremlins that we deal with. You can get an older model for less but the Power Probe IV has features to resolve complex Fuel Injection issues as well as finding the bad grounds for you. It lets you test each fuel injector and so much more. The cost at Amazon is about $135 complete, worth every penny.
Let us know what happens when you finish these tests, you got my curiosity going.
Best Regards and the Best of Luck!
Old 02-26-2017, 04:07 PM
dm_c4
dm_c4's Avatar
Wow thank you so much for this detailed answer!!
I will try this an let you know what I found out.
Old 02-26-2017, 04:48 PM
mickey5
mickey5's Avatar
You never indicated how well the starter turns over the motor.
Here at the Jersey Shore after hurricane Sandy, 1000's of cars were flooded with sea water. As the months passed these cars started to exhibit various electrical problems as the sea water residue corroded every contact. I mention this because we found that the wire itself corroded at the mechanical terminations. Check the battery cables themselves to make sure they're in good condition.
Good luck with your hunt.
Old 02-27-2017, 03:00 AM
dm_c4
dm_c4's Avatar
You never indicated how well the starter turns over the motor. .
Oh sorry if I forgot to mention. The engine starts right up and cranks like normal, there is no weakness or so. That's also why I think that it probably should not be the battery.
Old 02-27-2017, 09:38 AM
mickey5
mickey5's Avatar
Since the motor spins over with little hesitation and several features of the car were all affected at once I would checking out the fuse panel as Mc Closkey noted in his response.
Old 03-04-2017, 03:24 PM
dm_c4
dm_c4's Avatar
Can someone please tell me what these black things are that are on some of the cables (see picture)? There is e.g. a 20 on it. Is this some fuse or just a cable connector or so? You cannot open them.
Old 03-16-2017, 01:36 PM
dm_c4
dm_c4's Avatar
Well so far I was not successful
I replaced the battery, replaced the battery connectors, checked all cables I could find, replaced some that did not look so good, loosened all endings and cleaned them with anti rust and contact spray, replaced all fuses. All that changed nothing.
Well now I think I will order a new alternator or what do you think?
If this would not solve it neither the only other idea I have is to completely new wire all the lights and blinkers separately so that they don't interfere the car's electrics.
Or any other ideas or suggestions? Thanks for helping!
Old 03-16-2017, 04:02 PM
mickey5
mickey5's Avatar
Don't waste your money on an alternator. If its putting out 14+ volts its doing the job. To verify, take it off and take it to a rebuilder. They've got everything needed to spin it up and ckeck it out. Takes a couple of minutes and maybe a couple of bucks...maybe nothing.
Old 03-16-2017, 05:41 PM
dm_c4
dm_c4's Avatar
Well yes I am afraid that this will be waste of money, too
I just have the idea that I will take the bulbs out of the headlights and will test if the engine still starts to stutter when I turn them on. So I could see if it is a lack of voltage or a short circuit. Just an idea...
To Electrical problem - Please help!!
Old 03-17-2017, 01:26 AM
Cliff Harris
Cliff Harris's Avatar
That is a wire splice that connects the fusible link to the standard type of wire. It is covered with molded plastic to keep it from shorting to whatever.
dm_c4 (03-17-2017)
Old 03-17-2017, 02:59 PM
dm_c4
dm_c4's Avatar
Originally Posted by ihatebarkingdogs
If the headlights make the engine "stutter" when they are on, there is a resistive connection in a wire that feeds the headlights that is also common to the IGN switch causing voltage to drop enough to affect the coil being able to fire the plugs. Because the turn signals are also fed through the IGN switch, the same bad connection is causing the turn signal problem.
I would be suspicious of the C100 bulkhead connector.
A quick check would be to go to the fuse box. Find a fuse that is hot in RUN or START. Turn sig / back-up, IGN/Gauges, even cool fans. Put your + lead in the fuse test hole, and the - lead to a good ground. Start the engine and check the voltage with both the headlights on and off. Also check the voltage at the TAIL fuse with park and headlights. If you want, you can check as many circuits (fuses) as you want. Compare all these readings to those taken at the battery.
Keep in mind that all readings taken at the fuse box are AFTER the B+ wire passes through the firewall at C100. Readings at the battery of course do not. If you see lower voltages after C100, that's the place to begin. Always keep your - lead on the same place so you don't introduce any problems with the ground-side into your evaluation. Get a handle on the B+ side, then you can work on grounds.
HI, thank you so much for this great approach. Excuse me please if I'm not that expert, so can you please clarify some questions to me?
1. Do I get this right that it could be an issue with the ignition switch that causes the trouble?
2. The readings on the battery I do also take when the engine is running, right?
3. What is the B+ wire?
4. The TAIL fuse is the one for the headlights, right?
5. Do I take the fuse of the circuit that I test our or let it in the socket?
Thanks for helping
Old 04-02-2017, 09:30 AM
dm_c4
dm_c4's Avatar
Well today I finally did the checks.
I checked for fuses CLK, Tail, LCD, Brake and got the following 'table':
__________Headlight off ____ Headlight on
Batt+ ______ 12,4 ___________ 12,3
CLK, Tail ____ 12,3 ___________ 11,9
LCD, Brake __ 12,4 ___________ 12,12
This is for engine off. When engine is running then it's all something with 14,x Volts but the same differences.
So how does that help me now?
Quick Reply: Electrical problem - Please help!!
