Leaky valve covers?
Leaky valve covers?
Getting ready to tear into this motor but this leak makes no sense.
O-ring in the fill cap is in tact, cap is nice and tight. I clean the cover, I run the car for a few minutes and when I come back is what the pic shows.
I am making sure I am ordering all the proper parts and replacing what needs to be replacing, I just don't see how the cap is leaking after starting it once. Should I just do new valve covers/cap?
Or could this be a case of a bad PCV valve? I do have oil wicking up through two intake bolts.
Is your pcv valve plugged?
rebuilt A4, I only paid $2000 so I am not too upset. Car sat because owner broke his back and it sat outside -_-
I HOPE it's just a gasket, car only needs a suspension/motor refresh.
Car always felt like it lacked power, bad compression would make sense.
That will be your call but will know more when you see the walls.
Pushrodv8 (02-19-2017)
