what are the cc sof a 89 head and a lt1 head
have a lt1 short blk I know I have to change the front of the motor to a standard old school small blk ., my ? is I want to put the heads and intake off my 89. what will the compression be . what is the difference in cc s between the 2
and neither will small block chevy timing cover, water pump etc...
"....to quote OP change front of the motor to a standard old school small blk"
Many sources that have measured aluminum LT1 heads state 54cc
Mike
Mike
a fella named trevor gave greg who works for zr51 performance gave greg the parts to convert it . where are the block numbers located I will ck them and get back with everyone
If you are trying to build a small block chevy using a small block chevy block will be cheaper than converting an LT1 block to fit SBC components....
http://www.hotrod.com/articles/ccrp-...-block-engine/
