Issue With Radiator Fan, '87
I posted under C4 General that I'm looking at an '87. As I mentioned in that thread after returning from a test drive, with the car idling while the owner pulled a car out of his garage so we could pull the vette in to put it on the lift, the temp was creeping up. It didn't happen during the test drive, I assume (I know, ***-U & Me) it was because the car was moving and the temp didn't get high enough to need the fan.
I told the guy that he needed to work that out before I'd buy the car but I'm wondering if I'm making a mistake. This car was CLEAN. I saw nothing during my inspection, including an extremely clean underside, that gave me pause at all. It was obvious that the guy did what the car needed when it needed it.
Are there any weak spots in the wiring, temp. sensors, fan that are inherent in this year? Am I overreacting to something that I might be able to handle without much trouble?
The thermostat is a 190F one so you will see the temp at 190-200 on highway but climb up in stop start traffic.
Received 1,401 Likes
With the stock 195 t-stat and fan cooling setup, they're made to run hot for emissions purposes. If its not moving, a C4's temps will climb and climb to the fan setting.
Seems to me that what you saw was normal.
