Weird Turn Signal Issue 1986 Vert.
Old 02-22-2017, 11:40 AM
3D-Aircrew
Support Corvetteforum!
3D-Aircrew's Avatar
Default Weird Turn Signal Issue 1986 Vert.
My turn signal indicators flash backwards sometimes when the car interior gets hot. The left one flashes when I'm turning right and vice versa. The actual turn signals work correctly when this occurs.
Any thoughts?
Robert
Old 02-22-2017, 04:03 PM
Kevova
Kevova's Avatar
I would look at cluster and connector, seems like a ground or feedback problem
Old 02-22-2017, 04:23 PM
billschroeder5842
Zen Vet Master Level VII
billschroeder5842's Avatar
Received 1,140 Likes on 845 Posts
Try reground the cluster with a separate harness- these clusters are notorious for having bad grounds. Just a wire and a couple of "eye" connectors
3D-Aircrew (02-23-2017)
Old 02-23-2017, 11:35 AM
3D-Aircrew
3D-Aircrew's Avatar
Default going to rebuild the digital dash -- fix grounds then
I ordered all the stuff I need to repair my digital dash problems and I'll have an opportunity to chase down the grounds then. Thanks
To Weird Turn Signal Issue 1986 Vert.
Quick Reply: Weird Turn Signal Issue 1986 Vert.
