Bleeding the clutch on a C4
If it's properly bleed and still grinds or won't go into gear you may need a thinner plate between the firewall and the master cylinder.
I've had to do this on a few c4s.
Usually. 125-.175 is enough to move engagement to roughly the middle of the clutch throw.
If you need a thinner plate I have a few for sale.
I removed and set up my whole clutch m/c, spacers, rod, pedal and supporting assembly on a bench to discover what exactly happens; yes, a thinner spacer does increase the effective travel of the clutch m/c piston;
I reinstalled everything and with the transmission out but with the new clutch installed and the clutch disc held in place with the clutch plate alignment tool I measured the actual travel of the throwout bearing pulling out (my LT has a pull, not the more common push style clutch) ; using the measurements supplied to me by ZFdoc, I found that a spacer approximately one half the thickness of the original piece gave me the results closest to the measurements supplied by ZFdoc.
Needless to say I am very happy with the results, but the whole thing was a major PITA; it just reinforces my belief that nothing should be assumed and that everything should be checked; especially before reinstalling a clutch, trans, c-beam....well you get the picture.
gemsvette (05-28-2020)
I am finding that out. I must agree,
I am going to remove everything this weekend just to give it all a good look see and re-do it again and see where that will end up.
I did not remove anything from the 95 engine ie bell housing clutch etc... so i figured it was undisturbed and good to go. WRONG we had such a hard time getting the trans back in that now i am wondering if we screwed something up during the install.
well I found the problem. The release bearing fork was bent where the slave cyl connects as compared to the other one I have. I do not know if the 95 forks are that way factory but I am going to use the bell housing from the 92 that is from the trans that is in the car. I am changing the clutch out also since I am in there.
Red 91 (03-11-2017)
well that fork bent for a reason (sure age and being operated a zillion times could account for it). check that your fork mounting stud hasn't backed out, and by backing out, I mean unscrewing itself and moving forward, toward the engine
I am replacing the entire bell housing with the other one I have
Make sure the inside dia. of the throwout bearing matches the outside dia. of the input shaft.
well success, installed the 92 bell housing with a new clutch,(old one was in great shape) but since it was apart I figured what the hey. trans slid back into place like a glove and everything seems to be working as it should. Maybe the forks between 92 and 95 are different, and the 95 was the one I used the first time. this time it was the original one from the 92. I want to Thank everyone for all of the advice and guidance it led me to the culprit.
#33
#35
with LT4-396
To the OP, glad you got it figured out
#36
This talk of a thinner spacer caught my interest. I've had hydraulic issues in the past. I got that sorted and the air out but I've always felt that the shifter should slide into 1st/R with less effort when stopped. I never get a crunch or a lurch but in the back of my mind I wonder if I am getting full disengagement. Is there any way to test in vehicle? What are the risks of a smaller spacer resulting in too much TOB travel? The spacer looks simple enough to be fabricated in a home shop.
#37
Found spacers are cheap and order one. I can mill a tiny bit off at a time and trial/error to see if shifts improve. I guess another risk could be that if milled too thin it seems some constant pressure could be applied to the TOB, speeding its demise.
Will be a few weeks till I try it out.
#38
It really depends where the clutch is grabbing. If it's right off the floor then it needs a much thinner spacer. If it's grabbing an inch off the floor then you will still benefit from a thinner spacer.
If you break the clutch throw into 3 pieces the first 33% off the floor should do nothing the clutch should grab between 33%-66% then the last third does nothing again.
There is a post about full master cylinder throw and most cars are only utilizing 60% of it.
I started with milling .125 at first then .020 at a time and ended up with about .205 +/- .005 off the original thickness spacer.
Depending on the clutch you may also need a thicker/thinner shim. Some clutches are thicker then OE clutches
#39
Interesting breakdown. My clutch, as I remember it, has always been a high grabber. So it sounds like I may in fact need a thicker spacer based on your logic above. I guess what I can do is cut a .25" section if the extra spacer rather than mill it. This gives me the option to run the original spaced + .25" section or run the replacement spacer that is .25" smaller. Gives me options to try on both ends to see what works best. Should be an interesting experiment.
#40
^ I'm interested. Bummer that mine is in storage but def something I'm going to mess around with in the spring. Let's u know what you find out jmgtp
