1995 D/A with TunerPro RT
Cruising
Would anyone have nothing else better to do than decypher some log files? Or at least point me to where I can see what factory valus should be? No codes or errors. Nothing looks off based on my limited knowledge. The car sat 4 years outside before i got it and it idles and runs a little rough. Thinking it needs new injectors since i've replaced the opti, O2's, & TPS.
Slythee (03-21-2017)
Cruising
D/a
The first 3 are done with TunerPro RT using $EE-16188051-Y-body-V3.8.adx. The other two were done with EEHack. Any input is greatly appreciated.
Your IAC at idle is at 0 when engine is warmed up. You need to adjust your throttle body idle setscrew to close your throttle blades a bit. This will increase your IAC position . Try and get the IAC at about 40-50 for idle.
You are getting knock retard up to about 13 degrees pulled back during certain load conditions
There is also a DTC Code 78= FAN 2 FAULT
Cruising
Do you know what it takes to adjust that screw? I wasn't able to see into the recess.
Cruising
Throttle body adjustment
thanks, it was a t15 for mine. I made the adjustment but with continued AIC going to 0. I did a smoke test and found my throttle body leaking air around the top plate and through the throttle blade shaft on the cable side. Smoke was coming through the springs. I assume I'll be getting a new throttle body since I don't think I can replace the seal on that side.
wondering how bad of a vacuum leak that is causing. Can you try to back the idle set screw all the way down until the throttle blades are completely closed and the screw is just off the lever. Now turn up the set screw about 1.5 full turns until you can see throttle blades just opened from being bottomed out. Then can you read what the IAC is at that point. Remember to do this adjustment when the engine is fully warmed up. Trying to find out how much the IAC is compensating to set the targeted idle because of any leak.
Tuner Pro will only who you what the ECM is telling the IAC to do, not what it is actually doing., Trust me on this.
Use an OHM meter and check between A and B? Should be greater than 20 OHMS. Check OHMS between C and D should be greater than 20 OHMS? If not replace IAC.
Not sure of color code, but
Blue wire white stripe to A on IAC connector.
Blue wire black stripe to B on IAC connector.
Green wire white stripe to C on IAC connector.
Green wire black stripe to D on IAC connector.
Cruising
Cruising
THANKS FOR ALL THE INPUT.
