1996 lt4 stall and studder help!!!!!!!!!
Okay so i have a 1996 lt4 obviously 6 speed... i did a cat delete x pipe in place of the resignator and magniflow mufflers about 4 months ago, and i get a constant check enginle light because of the cat delete, but it wasnt causing any problems so i wasnt worried about it. But about 2 months ago my icm went out and in the process of trying to figure out the problem of my car not starting i replaced the opti, all new plugs and wires, the coil, and then the icm last
But none the less the car fired up and ran, but i now have a studder right at 5000 rpm and i cant figure out the problem. Its almost like it hits a rev limiter at 5000 rpm in any gear every time, i cant go past it.
And yesterday i replaced a broken roller rocker hoping it was the problem, and it not only didnt fix the studder problem i now randomly stall when i come to a stop... the car idles way down to around 300 or 400 rpm and just dies, but fires right back up and i can drive away fine.... the stall problem is random, somtimes it does it and somtimes it doesnt.... but the studder at 5k its consistant and i can't figure it out...
SOMEONE PLEASE HELP ME!!!
Did you use the proper thermal grease on your ICM. Clean your throttle body and IAC. How old are your o2s?
Could be both do not reuse gaskets and make sure the IAC passages are clean.
***UPDATE*** i havnt looked into the o2s yet, but now the car will die if i even try to drive it and most of the time wont start... i cleaned the IAC very well, and found a couple vacuum leaks using starter fluid. I replaced the bad line, and any others that i thought could be a problem... didnt help at all... at idle it runs like crap and will die. When it does die it wont start back up, i have to wait for a while then it will fire up and repeat...
At 5000 RPM the throttle is probably close to wide open and the O2s are out of equation. They are not used for A/F calculation at high power. You have to have it idle first before you worry about the high end. Have you checked the EGR for leaks and proper operation with a vacuum gauge and the vacuum release checked.
I would get a professional smoke test and make sure the manifold is sealed properly as well as the other areas. I would also have a good scanner connected to check the IAC counts, fuel trim and o2 voltage swings.
I would do a WOT run to see if it holds pressure. IF so, the pump is good. After that, I'd check the IAC counts. If it holds at 20-30 counts when it is at stable operating temp with everything but the motor off, I doubt there is a leak. OTOH, if he can't do that simple thing, it means there is a leak somewhere and the ECM won't let the IAC open which explains why he would turn the screw all the way out and still have 0 counts.
I agree that the O2s won't cause a problem at 5000RPM (I doubt this could be your problem). If you have good fuel pressure 40-45psi at idle, I suspect your new optispark.
Are the rockers still the stock 10mm stud, non adjustable ones or were they replaced with adjustable 3/8 ones? If they are adjustable and you over tightened it it will cause a rough condition.
Thanks for all the responses guys! The 5k studder acurred after i changed the opti, icm, ect... other than not being able to go past 5k it ran fine in the bottom end. My new problem (dying, rough idle) acurred right after i replaced the roller rocker, but the car sat for a month waiting on the rocker...
They are stock studs and non adjustable, but my concern is the rocker i baught is not an oem, and it came with an adjustable nut (with a set screw in it)?? I just used my stock nut from the other rocker... i could not find a direct replacement? Could that be a problem? If so where can i find an oem lt4 1.6 ratio rocker?
Thanks guys
Thanks guys
Lt4 engines do not have EGR valves. I would look at the new optispark you replaced, there are a lot of new defective/inferior ones out there!
