96 LT-1 fuel pressure
Old 03-20-2017, 12:32 PM
HT1663WB
HT1663WB's Avatar
Default 97 LT-1 fuel pressure
Hey guys, hoping somebody can help me out. 96 LT1..fuel pressure at idle is 20 psi. When I disconnect the vacuum to the fuel pressure regulator the gauge only moves to 21psi. Gauge does not change when revving...if I stab the throttle it will stumble, sometimes stall. If I roll on it breaks up around 3500-4000 rpm. I've replaced the opti 6months ago. I'm thinking fuel pump. I hate to just throw parts at it. Thanks, Bill
Old 03-20-2017, 12:52 PM
aboatguy
aboatguy's Avatar
When was the last time you changed the fuel filter?
IMO
one of three things
1. Clogged filter
2. Old fuel pump
3. Bad regulator
If the fuel pressure regulator is good, I'd move on to fuel filter if its original, since its a maintenance item
Good news is pulling the pump is really easy on a C4.....
HT1663WB (03-21-2017)
Old 03-20-2017, 12:53 PM
HT1663WB
HT1663WB's Avatar
IMO
one of three things
1. Clogged filter
2. Old fuel pump
3. Bad regulator
already replaced the filter..did that today. Pump is original 150k
Old 03-20-2017, 12:59 PM
aboatguy
aboatguy's Avatar
Did you pinch off the fuel return line IOT check fuel pressure regulator?
If you did that and line pressure didn't jump up its time to look at the pump.
Good news is you can remove the pump easily and it may be a dirty sock or leaking pulsator etc... but all accessible from the top without dropping the tank.
<Mike
Old 03-20-2017, 07:28 PM
HT1663WB
HT1663WB's Avatar
All good now. Thanks Mike! Appreciate the help.
Old 03-20-2017, 09:26 PM
aboatguy
aboatguy's Avatar
what was it?
Old 03-21-2017, 09:03 PM
HT1663WB
HT1663WB's Avatar
what was it?
Sorry..fuel pump. Thanks again, Bill
aboatguy (04-03-2017)
To 96 LT-1 fuel pressure
Quick Reply: 96 LT-1 fuel pressure
