84 corvette leaky window
When it rains or I go into a car wash driver side up at the top of the window has a bad leak. What could cause this. The targa top seal or the door seal and what would I need to buy to fix it. Thanks...
Zen Vet Master Level VII
Yes and Yes,
You need to make sure you have a good seal on the top window. If your seal is bad, you need to replace it. If you seal is good, you may have to adjust the window up a skooch.
