Corvette won't start
I have a 1990 Corvette convertible (As my user name states) and it ran fine yesterday, went to go start it up today and...nothing. The dash lights go dim when the key is turned and nothing happens. When the ignition is first turned on, you can hear the fuel pump coming on for a second, so I'm pretty sure that's fine. I used a remote starter on the starter and the engine turned over, but didn't fire up. Made sure that the distributor was getting fire, and it is.
Any ideas?
Any ideas?
Does the battery take a charge? That would be the first issue I would address.
Verify fuel pressure? Maybe pull a plug and look to see if it's getting fuel?
Yeah, probably not keeping the car from starting but it will need to get addressed at some point. I have an 85 without the VATs so i don't know if that could have something to do with it. Not sure how it acts when voltage drops on the system.
Crank it and spray some ether in the manifold. If it catches, we have a fuel issue
Tried another battery that was fully charged out of a chevy 1500, same issue, turn the key and nothing happens except the dash lights dimming. Starter won't even turn over. Since I had a remote starter hooked up to the starter to make sure the starter was working, I now know that it's not the starter, and it's not the battery either since that battery will start the truck every time.
VATS issue, or maybe a starter relay issue?
If that isn't the issue, you may have to tow it to do a draw test
Code 46 - VATS.
Any way to scan if the pass key is and is authorized by the ECM?
Might check the ground cables for corrosion where they connect to the chassis. Especially since it turned over when connected to a starter that was providing a different ground but wont even with a fresh battery.
IDK. I agree it is possible but how to have it checked without a VAT 40 meter? I had a bad starter once and it would start when it was jumped or battery charged. Happened often enough that it worried me. For ***** and giggles, I hooked the battery to another car and it worked. Thing I am worried about is that if the starter is old enough, it might not be a wise thing to assume it is in good shape. Doesn't hurt to look before he tows it for a starter draw test.
But if the engine will not crank, why does it have the lights dim? Doesn't that indicate that a huge amount of power is demanded hence the dimming of lights? Assuming battery is ok, that is. Pump should be on for 2 seconds and not much of a draw. So what is causing that draw?
And my understanding is that with a VATS issue the motor would still turn with the starter, just not crank. The lights dimming make me think there is an amp draw on the battery that the circuit can't carry and causing a severe voltage drop. My vote is for a wiring issue. Corrosion, frayed connection, bad cable......
But if it was the VATS how is it turning over on a starter and not without it?
Think you are going to crank it immediately after trying? Think again, buddy. No cranking for 10 minutes for you.
Signed: The VATS ****
If VATS doesn't like you, it won't crank. I just did it on mine. You will hear it prime the pump. It just won't crank. No starter action. It won't throw the actuator or turn
