Any battery experts here?
racerseks (03-27-2017)
Fairly certain these are maintenance free batteries. I have a Duralast that's probably about 6 years old now and it's been fine, they are not bad batteries. This battery has 3 year free replacement so you can take it back to Autozone for them to check out, but I would be surprised if the battery is bad.
If you park the car over the winter and can't trickle charge I suggest a quick disconnect ****. I use one, they work great. The car will draw about 30mA of power, so over a few months that can cause the battery charge to drop.
http://www.ebay.com/itm/Battery-Disc...RUpPLT&vxp=mtr
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
I have a Duralast Gold in my C4. In fact, the last two have been DLG's. I have never had a reason to believe that they are a "maintenance-free" battery.
It is my understanding that no battery that has removable fill caps is a true maintenance-free battery.
As they say, the devil is in the details. That 2 batteries are made by Johnson Controls means nothing to me. Wouldn't even matter if the came out of the same factory. Private Label means I make something and slap your label on it. It doesn't mean made to the same specs.
I am on my second duralast gold, they are NOT a maintinence free battery I have added distilled (only distilled no smoking by the way) to the bottom of the plastic so you see the marble effect. You will pep up your battery again. They are ok batteries and I like the warranty.
rocco16 (03-27-2017)
Yea, I can't really complain. Three years is pretty good, and they've never given me problems with the warranty...
I gotta say, they do stand behind their warranty.
I had a quick-disconnect on it, but wasn't comfortable with how cramped it was in there. That's when I put the 8mm open end on my keychain, ha ha...Sure sign of a C-4 man!
Thanks for your comments...
I'll t you all know if it doesn't hold a charge...
#33
It comes as no surprise to me...Autozone told me the exact opposite. It's why I never trust just one opinion or statement on anything...
#34
Flatulent Dwarf
Get yourself a Battery Tender while you have the battery out of the car, they come with a quick connect pigtail. I've used Battery Tenders for years on hot rods, motorcycles and most any equipment that has to go unused for any length of time. Here's a link to the one I buy, You can get them cheaper at Amazon or CycleGear...usually around 40 to 50 bucks.
http://products.batterytender.com/Ch...derR-Plus.html
later, tiny
racerseks (03-28-2017)
#35
I've always figured that if the battery has removable caps, it's not maintenance free....but i've only tested that for 30 years so I could be wrong.
later, tiny
later, tiny
You're definitely onto something, man! Thanks...I'll check out your link, but I am pretty fond of having that 8mm on my keychain. Been there for years now...
Just checked out your link..Sorry, I thought it was a disconnect. Will check it out...thanks!
Thanks!
#37
found this http://www.bestcovery.com/duralast-gold-car-battery the review says maintaince free.
#38
And to confuse things more, on their website, Autozone lists their "Platinum Series" as "Maintenance Free", yet mention nothing for their gold series.
You'd think they'd label them on the battery itself. Probably never thought of it...comical.
#39
Here in the UK, we all use Tayna to supply batteries on our American cars as they walk the walk.. (apart from Optima which seem to have problems and we avoid them)
https://www.tayna.co.uk/American-Car...es-S701-1.html
and we use these tenders..
https://www.tayna.co.uk/CTEK-MXS-5.0...5.0-P8692.html
#40
Connect a volt meter & charge @ 50 amps for ten minutes. If voltage exceeds 16V while charging the battery is sulfating = it will die soon.
Load test: 200 amp draw for 15 seconds. If 10.8V or better after 15 seconds = good to go. If less than 10.8V after 15 seconds recharge then load test again. If less than 10.8V the second time replace the battery.
Good luck
Good luck
racerseks (03-31-2017)
