instrument cluster 88 c4 question
just was curious - on my 88 c4 chevy sent my cluster off to be rebuilt -
before and even after I noticed the lights in it are sometimes super bright like normal and sometimes dull or faint -
what other causes could lead to this '
and also I just replaced my exaust manifold gaskets and sometimes when reving in park in my garage I hear a slight pop, could a slight leak in the donut gasket cause a pop occasionally on the start of a rev
thanks all
thanks all
You do realize that the cluster responds to ambient light sensor - brighter typically in very bright daylight conditions and dim in lower light conditions. Is your issue when park or headlamps are on only or both daytime and "lights on" operation.
ok
almost seems like maybe voltage related, but I'm not sure
Who did your cluster rebuild/ You might want to quiz them on exactly what they did! Did you ask them to check and report OR did you just ask that they correct a particular issue?
Bulbs? Light sensor?
Did you have the bulbs changed? It's possible that there is corrosion on the pads/holders where the bulbs make contact. Could produce those symptoms. A cold solder on the light sensor could as well.
