will my Dana 36 be strong enough for 500 HP Auto
just added 408 stroker 520 HP 550 tq, performatrans 460 trans full manual
valve body. to my 85
can the dana 36 355 ratio last for a wile... what is its breaking point to hp and torque. any average on what breaks first
as always, thanks guys..... you always help
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
C4 of Year Finalist (stock) 2019
St. Jude Donor '08
It may live a long time on the street if you are careful with it. On the track with slicks will not be so good if it hooks.
I'd budget for a D44 in your future.
IMHO...not a chance on the track with tires that hook. A Dana 44 is in your future if you want to play hard.
I had a 3.73 D36 in a light car (2800 lbs) with 315/35 100 treadwear tires and 6 speed and it lasted through quite a bit of 540 RWTQ acceleration but no hard starts. Now has a D44
3 runs at the track with slicks.
you can make them last longer with batwing/cover conversion that Zip Corvette sells.
BUT
thicker stronger metal is thicker stronger metal, there is no getting around that, the D44 has thicker stronger gears and metal but even they can be broken
The batwing/cover from Zip has blocks that hold the bearing blocks in place, just like the batwing/cover from a D44. Machining of the tops of the bearing blocks is required for installation.
For a spirited cruiser these are a less expensive alternative. For a high HO tire frier, who knows how long they can keep a D36 together
BUT
Received 1,401 Likes
Its not the HP that breaks it, its the torque. My engine makes that much power through a 36, and it runs fine on the street.
But if you go slicks, it may last 10 passes, 50 passes, or not 1 pass. it'll go whenever it wants.
My 383 didn't run slicks. Just decent tires. Broke the gear. Making 420 RWHP. I do hit it on the ramps but no track runs.
2 schools of thought. Drive the hell out of it and dump it when it breaks, repair if economical and sell. Another is to dump it while it has value and get a D44. First option can leave you stranded in the middle of BFE and the other, you choose the down time. Your call.
How do you define "a wile"? I didn't make it a year on the D36. IF by "a wile" you mean will it make it to the supermarket? Probably. If you mean 3 years, yes but you will have to putz it like there is an egg between your foot and the gas pedal.
There are 3 answers to this question: NO, NO and NO. Even a Dana 44 with a good tire won't last!
I disagree with anyone that says to run it till it breaks.You can do damage to the under side of the car or have an accident(not likely but has happened).I have a built 383 in my 87 running mid to high 11's with a built d44hd from an 86 parts car I got with no eng. for $300.Yup,that's right,$300.He didn't know what he had.Anyway,I sold my d36 for $600.There are guys that will pay that,especially if they are building a custom hot rod.Ask $650 for it and take $600.You might have to sit on it for a while but maybe not.Craigslist will get it sold.I put an eaton truetrac in my d44,not cheap,$830 but well worth it.No more worries of breaking spider gears and ruining the whole basket and ring & pinion or worse,the case.Still have the stock axel hubs and am concerned on how long they will last.Will eventually go to summers bros. for them.
