lost wheel lock key, need info
Hello all,
I have just returned after a 5 years or so without owning a Vette. Anyway I am back. Just bought a 2 owner 69K mile 94 Bright Aqua Metallic coupe. The car is near perfect and was very well taken care of, however I can not find the wheel key, and do not know where the code is to get a replacement. I need to swap the rear wheels on the rear around as they are not right. The tires are not directional, but the PO or his shop did not get the wheels in the right position. Anyway the key is not in the car. So does anyone know where the RPO tag is on a 94 coupe, and would it have the key code on it? I am pretty sure a tire shop can get the locking lugs off but if I can find the correct key would be nice. Thanks in advance, Kim
Hello all,
But I have contacted Amcor and supplied them with a high quality photo and they have matched it up and sent a new key. Which I promptly threw the lug nuts and key in the garbage after removing them.
Your local dealership might have a full set of keys. Might be worth a call.
Thanks, I looked in and under the passenger rear compartment (where it should be), even removed the amp and felt under the styrofoam (that was fun, LOL), not there, not in console or door panels either. Where is the tag that has the key code? any idea? Kim
I believe they took them off once on my F-body at the body shop so they had a way to get it off. I replaced them with lug nuts and tossed the silly things away like you did
Amcor was the original wheel lock key manufacturer.
And yes, meant seats.
I don't know anything about your 94 but in my 91, there is a left and a right. Is that what you are trying to do? See my post HERE and see if it applies to you. Especially post 7
Looking at the picture of your car, i thought the fins were supposed to go towards the front. That would mean that the front wheels are wrong. Maybe im thinking of different wheels.
Any good tire shop will be able to remove the wheel lock. It will get destroyed in the process, but it will come off. Then just replace with a regular GM lug nut that has the external threads for the plastic cap.
Any GM Dealer will have the lug nut and cap. They are a generic style that was used on a wide variety of GM cars. Or you can buy a new set of chrome acorn-style lug nuts. I would not get another set of locking lugs unless the car is kept outside and you have it parked in an area where vehicle thefts or car prowling is an issue.
IMO, they are looking for newer cars with more common tires not some fat tire that fewer cars can fit unless it is a really popular car if they are looking to turn it around quick.
When I bought my 92 it has 19 regular lug nuts and one lock
neighbor brought his craftsman lug removers over and it was off in less than 5 minutes
seeing that you can buy the tool at sears are the locks really serving a purpose?
Good luck.
PS Found some different lug nuts (when I changed rims) that hopefully will frustrate the heck out of any wheel thief. They take a 7 spline socket to fit them (every one of them). Plus the lug bolts are recessed into the rim, so they will have a heck of a time with something like a vice grips or grabber tool due to access issues (hopefully). Hope to never see it attempted but I'm doing my best to prevent it from happening.
Had a friend with this issue, went to local Discount Tire and they were able to remove them without damaging them. Replaced with regular lug nuts for the time being. I've seen where they've removed them without the original key before. Don't know if they have a stockpile of various designs or what but sure worth a check.
Good luck.
Good luck.
If you want to worry about these things (spend time and thought), why don't we cancel the insurance and I can spend the money on blow and hookers? I pay insurance so I don't have to worry other than a small outlay for the deductible. At a $500 deductible, it isn't worth my getting worried and doing all kinds of gyrations, etc.
Found some different lug nuts that hopefully will frustrate the heck out of any wheel thief. They take a 7 spline socket to fit them (every one of them). Plus the lug nuts are recessed into the rim, so they will have a heck of a time with something like a vice grips or grabber tool due to access issues.
Mine were made by Excalibur, p/n IK303, 12 mm-1.50. Get an extra "Spline Key" socket. One for the car, and one for the tool box.
That's the ones and I have if they have 7 grooves down them. I also got 2 sockets like suggested: one in the car and one in the house. Regular and metric sockets don't fit them, you need the special socket to engage the grooves in them, and 7 makes them an odd number.
Here is my take on this. My wife has the same thought as you do and this is what I tell her:
I already had some low life try to steal the rims off my truck and he would have had (apparently) he not noticed they are 7 bolt rims instead of 6 or 8 so basically unusable to anyone but someone with the right F150 with the 8200 lb suspension under it. There aren't a whole lot of those around either. I had to go to Alabama (I live in Minnesota) to find rims for my trucks winter tires, so I don't look forward to chasing replacements down.
I'll add protection where I can. Saves headaches in the long run but to each his own.
