AIR BAG SEAT BELT CODES 1990
I had my car scanned and it came up as CODE DTC -16
does anyone know what this means . i had it scanned because my air bag light was on and my seat belts sign
i would like to try and change the broken part myself
thanks mj fox
thanks mj fox
Re: AIR BAG SEAT BELT CODES 1990 (mjfox)
The seatbelt light comes on whenever the airbag light is on. The problem is there is corrosion between your airbag sensors, and the frame of the car. There is one sensor on the frame under the battery and another one on the other side of the car under the windshield washer fluid tank. You have to remove them and sand down the frame to bare metal, put some silicone grease on the metal and on the bottom of the sensors and instal them with new bolts and lock washers. The reset the light using the tech tip in the tech tip section of the forum. Make sure the battery is unhooked before you do all of this. :cheers:
