Hissing Sound from Brake Pedal
It feels like I don't have power brakes any more! When I press on the brake pedal, I get this hissing sound. The sound remains for as long as I have the pedal depressed.
I took a look and can't see anything obvious but it looks like everything is tucked behind the floor boards. Brake fluid is full. I now have to press really hard to stop. I still stop just fine but it makes me feel uncomfortable. Any idea what's wrong?
Re: Hissing Sound from Brake Pedal (silver & red CE)
Thanks for the quick response. Great forum! :cheers:
I am going to break out the shop manual now. Is this a do-it-yourself kind of fix? Where the heck is the booster located?
Re: Hissing Sound from Brake Pedal (Shawn93PoloConv)
It's the great big plack pancake type thing that your master cylinder is mounted to. I've never done one on a vette, but yeah typically this is considered a do it yourself job.
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: It's the big round tank right behind the brake master cylinder!
:cheers:
:cheers:
Former Vendor
Back when I was a scrub :rolleyes: I fixed the crack with a piece of mailing tape, you know the kind that has tread through it. Worked for about 1 yr! :D I eventually changed it because it started collecting dirt and looked like crap. It cracked were the large vacuum like connects for the booster to the manifold.
Re: Hissing Sound from Brake Pedal (ski_dwn_it)
It's a very easy job on a vette. Just get a few long extensions and a universal. There are 4 nuts under the dash that have to be removed. Other than that it's a straight forward job.
