LT1 reverse flow cooling question
Does the coolant temp sensor read the coolant temp after the coolant has been run through the radiator and is enroute to the heads?
It think so, but I forgot at what point in the coolant flow the sensor reads the temp of the coolant.
Re: LT1 reverse flow cooling question (Lone Ranger)
There are two sensors. One is in the water pump, the other is in the head. The one in the head is there just for the analog gauge. The digital gauge and the ECM reads from the sensor in the pump. I don't know where in the stream this is at.
Re: LT1 reverse flow cooling question (Oldman)
The coolant temperature sensor in the water pump measures the temperature just before the coolant goes back to the radiator.
The order of flow for the reverse flow LT1/LT4:
1) from the radiator into one section of the water pump
2) through the thermostat
3) through the heads
4) down through the block
5) back to the the other section of the water pump and the coolant temperature sensor
6) back to the radiator
Tom Piper
Tom Piper
