How much HP will stock fuel lines support?
St. Jude Donor '05
The pump has been upgraded. But I'm wondering if the fuel line diameter could pose any problems? Could the stock diameters support 500+HP?
Kelvin
Kelvin
Re: How much HP will stock fuel lines support? (88-406)
Unless you're going wayyyy rad...don't worry 'bout it. I've seen 600hp vettes with the stock fuel lines and no problems.
Cruise-In IV Veteran
Cruise-In V Veteran
Re: How much HP will stock fuel lines support? (drive it)
it depends more on the pump than the line up to 600 hp like drive it said put a walbro 340 and use a hot wire kit remember to change the filter every 1000 miles if it is a high horse power car :cheers:
