Any one using alum Dart Pro 1 heads
If so how do they flow, and do you know where or whom I can call can to get flow numbers for the 200-215 CC heads? :confused:
Re: Any one using alum Dart Pro 1 heads (ld85)
I have a set of the Pro1 200's on my new 406. You should be able to get the flow numbers from Dart's website at http://www.dartheads.com They have really good looking ports and I really didn't do anything to mine except check the valve job, do a minor cleanup surface job, and put bigger comp springs and retainers on for my hyd. roller.
Re: Any one using alum Dart Pro 1 heads (eguyett1985)
Ah...here ya go!! http://www.dartheads.com/sbpro200.htm
Have you dynoed your motor? I am building the same except the SuperRam part and the bore.
Not yet, I'm just finishing it up now...gotta paint it still and finish putting all the intake stuff on next weekend and I should have it running in a couple of weeks. I have access to an engine dyno but it's a real hassle with EFI engines so I'm gonna get it in the car and use the chassis dyno at Whipple Superchargers and their Horiba Air/Fuel meter to tune the DFI. I'll keep you posted. I have some pics of it I'll post in the next week or so!
[Modified by eguyett1985, 7:11 AM 12/3/2002]
