Oil Pressure question again
Guy,
Please post your oil pressure, I don't know if my oil pressure is OK???
My car: Rebuild engine with Total Seal Piston Rings, regular oil pump. The people at Total Seal doesn't recommended high volume oil pump.
Cold engine Oil Pressure: ~64 psi @ 1500-1700 rpm
~45-50 psi @ 600-700 rpm (idle)
Operating temp Oil Pressure: ~44-46 psi @ 1700-1900 rpm
14-18 psi @ 600 rpm :confused:
I rememeber before rebuild the engine never went below 20-22 psi idle.
Is 14 psi at idle too low?
Thanks,
Viet
Thanks,
Viet
Received 1,400 Likes
Re: Oil Pressure question again (VQT88Vette)
Mine gets 50-60 psi at cruise and about half of that at idle.
Your idle is just a little low, what oil pump did you use on the rebuild?
Was a new pressure sensor installed with the rebuild? I have found that they can vary a few PSI between manufactures, especially seen at the lower pressures.
Re: Oil Pressure question again (87SAM)
Re: Oil Pressure question again (vader86)
Would the Total Seal Rings set up has anything to do with low oil pressure at idle? At crusing speed, the pressure stay between 41-50 psi.
