LT1 install in 1991 L98
2nd Gear
How difficult is it to install a 1992-1994 LT1 engine in a 1991 corvette with the
L98 engine. Will anthing have to be altered?
Re: LT1 install in 1991 L98 (ROSCOEP5)
The entire wiring harness, the ECM, the exhaust system, the coolant system, the A/C system (if you choose to retain it)...it's a major project to do it, but it's been done. If you were going to do it, you might as well go all the way and put an LT4 in the car.
Received 1,400 Likes
EVERYTHING
Not cost effective at all.
You have to swap the engine wiring and A/C I am in the middle of puting a LT1 in my 84 I had the ECM reprogramed for emission delete and VATS by-pass as well as having it programed for no Tranny controls and a LT4 Hot Cam. I bought a kit a while back for my 700R so it does not need a CPU for TC lock up. You will need the Assy. Bracket from a corvette LT1 the F-body bracets will Hit the frame. As far as cost efectivness it just depends on the deal you get I got My LT1 (only 23,000 miles) with ECM, Wiring and Tranny for $1200 sold the Tranny for $500 and sold my L83 for $1000 got the corvette braket for $50 and the A/C stuff for $150. so I was still a couple of hundred bucks up when all was said and done. I decided to go ahead and rebuild it and install a LT4 hot cam and springs before I put it in the car the block is at the machine shop now being honed and cleaned. I also got corvette LT1 exhaust manifolds I will be out of pocket about $1000 not to bad considering I will have a 95 LT1 with 0 miles.
Re: LT1 install in 1991 L98 (ejfagala)
What is your objective? If it is horsepower, then forget the LT-1, you can make a ton of power with the L-98 block and heads. If you love to tinker, then get a LT-1 manifold and modify it to fit your engine.
